Transmission gear hunting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by seang, Nov 20, 2018.
  1. Nov 20, 2018 at 9:43 AM
    seang
    seang [OP] Eternal Noob
    TX
    17 White Off Road
    Question for you guys about the transmission hunting gears...
    ive seen discussion about stumble on take off, but i dont recall seeing the issue i am having.
    when i am going about 70-75 using cruise control on a fairly flat surface sometimes it will drop from 6th to 5th and not go back to 6th by itself. occasionally if there is a small incline it drops to 4th and stays there for a while. i press the gas and it will end up shifting to 5th then 6th then ride in 6th for a while and the cycle will end up repeating.
    I havent seen this on a TSB specifically. anyone experience this?
  2. Nov 20, 2018 at 9:44 AM
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
    2016 SR5 Access Cab V6 Auto 4wd
    Limited wheels, extra rope hooks in bed.
  3. Nov 20, 2018 at 9:45 AM
    Tac0Tic0
    Tac0Tic0 новий член
    SLC, Utah
    17 TRDOR QS
    OVTune Volk TE37XT 17x8.5 295/70r17 G003 Yukon 5.29 differential gears Cab Mount Relocate Icon Coilovers Icon AAL Uptop Overland Bed Rack Maxtrax Baja Designs Squadron Pro Ditch Lamps Rough Country Speedometer Calibrator
    So your concern is?
  4. Nov 20, 2018 at 9:47 AM
    daddy_o
    daddy_o Well-Known Member
    Bossier City, La
    2018 TRD Sport, Inferno, w/tech package
    Factory Blackout package, Soft roll up bed cover, Cheap seat covers, Front and rear dash cam, AVS in channel vent visors
    Does the truck maintain the speed set on Cruise control? If so, the computer is mapping for max fuel efficiency, there may be something that is making it determine 5th is better than 6th.
    jsinnard likes this.
  5. Nov 20, 2018 at 9:47 AM
    seang
    TX
    17 White Off Road
    driving 70-75 in 4th for extended amounts of time when it really should shift back to 5th or 6th.
  6. Nov 20, 2018 at 9:48 AM
    Clearwater Bill
    Billy
    Largo Florida
  7. Nov 20, 2018 at 9:48 AM
    Kilokato
    Kilokato Go Vols!
    George
    East Tennessee
  8. Nov 20, 2018 at 9:50 AM
    seang
    TX
    17 White Off Road
    yes, it holds that speed. if it were into fairly strong head wind, or up hill, i get it, but just pretty flat... low wind.
  9. Nov 20, 2018 at 9:51 AM
    LivinOnEdge
    LivinOnEdge ¯\_(ツ)_/¯
    Land of The Lost
    Four wheels and a refrigerator
    That's the transmission of this generation.
    Tig3r_Bit, Kilokato and Dkurtz42 like this.
  10. Nov 20, 2018 at 9:58 AM
    daddy_o
    Bossier City, La
    If its holding the speed then let it do its thing. By you pressing the gas you are interrupting the computing cycle and throwing the current mapping out of line. 5th and 6th are both overdrive gears, so when it drops let it drop.
  11. Nov 20, 2018 at 10:00 AM
    Dkurtz42
    Dkurtz42 Bill Hwang
    David
    Barberton, OH
    2023 Tacoma DCLB TRD SPORT 4x4
    - Gator ETX Soft Roll Up Tonneau - Clazzio black leather seats - Nitto Ridge Grappler 255 80 17 tires - Supreme Suspensions 2" and 1" lift
    To get to, and stay in 6th you must mentally will your Tacoma to be in 6th. Weak minds will only achieve 5th gear.
    THEPBEAR, brehew, Cclogan8 and 4 others like this.
  12. Nov 20, 2018 at 10:09 AM
    Dr TMAC
    Dr TMAC Well-Known Member
    Taylor
    Houston, TX
    2017 Black Toyota Tacoma TRD OR 4X4 DCSB
    This feels like a true statement.
  13. Nov 20, 2018 at 10:10 AM
    Dr TMAC
    Taylor
    Houston, TX
    This describes my drive to work everyday, even after the TSB which did help a lot but not enough. Probably my E rated KO's aren't helping. 285's.
  14. Nov 20, 2018 at 10:31 AM
    tguil
    tguil Well-Known Member
    Nebraska
    2018 Double Cab TRD Sport 4X4 AT
    Just shift into "ECT" and "S5" and never look back. I have found that it doesn't affect your mileage all that much compared to driving in "D" like normal people do.
    THEPBEAR likes this.
  15. Nov 20, 2018 at 10:51 AM
    seang
    TX
    17 White Off Road
    thanks for the responses. taking it to the dealer next week for the ECU update. they were the ones that suggested it after i explained the symptoms.
    Tig3r_Bit and Kilokato like this.
  16. Nov 20, 2018 at 11:05 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Push the clutch in and shift to 6th, problem solved!
    brehew, KBOX, Tig3r_Bit and 3 others like this.
  17. Nov 20, 2018 at 11:49 AM
    Tacoma2020
    Tacoma2020 Well-Known Member
    Which dealer?
  18. Nov 20, 2018 at 12:28 PM
    seang
    TX
    17 White Off Road
    Jeff Hunter in Waco TX
  19. Nov 20, 2018 at 12:34 PM
    sfr4dr
    sfr4dr Well-Known Member
    Truckee/Tahoe CA
    Currently trying to pick my next Toyota!
    Do the TSB and if it comes back or doesn't solve anything look into the Shiftsense.
  20. Nov 20, 2018 at 1:44 PM
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    I guess some people dont like it when their automatic transmission shifts automatically.
    How is the truck supposed to know what gear you want it in as long as it maintains speed in cruise control?
    It's a 6 speed with double overdrive, not many vehicles have that so it drives a bit different than the rest.
    rickm, Stocklocker, Tig3r_Bit and 3 others like this.
