Transmission gear hunting
Discussion in '3rd Gen. Tacomas (2016-2023)' started by seang, Nov 20, 2018.
  1. Nov 21, 2018 at 1:14 PM
    #101
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    ejewels[QUOTED] likes this.
  2. Nov 21, 2018 at 1:14 PM
    #102
    ejewels
    ejewels Well-Known Member
    CT
    2018 MGM TRD OR 4x4 DCSB
    6112/5160/Dakars/Pro Tacoma Wheels
    Unlike you, I like to make sure of things before making a decision. Plus, it’s none of your damn business at what questions I ask or when I ask them. Are you a mod? That’s what I thought.
    You call me anal retentive. Ever hear the expression “there’s no such thing as a dumb question”? Apparently not. It’s a shame you have so much hate you need to bully noobs or those with less taco knowledge.
    Maybe its jealousy that I got a better lift setup than you?
    And with all this knowledge, you should know that each truck is different and responds differently to lifts. My stuff was installed by 2 professional working mechanics and I’m confident in the install.
    Anything else? Sad that you’re in Spain right now, at night and arguing with someone on the internet. I certainly wouldn’t be doing that if I was there. I loved Barcelona. And Madrid.
  3. Nov 21, 2018 at 1:16 PM
    #103
    seang
    seang [OP] Eternal Noob
    TX
    17 White Off Road
    then what does it matter if its cruise or my foot?
    honest question.
  4. Nov 21, 2018 at 1:18 PM
    #104
    stun gun
    stun gun Well-Known Member
    Aaronski
    Tacomas.
    17 4X4 sr5spd/01 LT sr5spd
    You sound young, indeed. I can’t think of anything I’d rather be doing if I was in Spain. Fuck yeah, arguing on the internet. Fuck Spain.
  5. Nov 21, 2018 at 1:18 PM
    #105
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Cruise doesnt see a hill coming up, you do so you anticipate the increased load then squeeze the gas pedal to compensate. Truck begins to learn this then holds gear longer.
    CC cant see the need for the increased load so it uses shifting to compensate to maintain set speed, it has no idea how high or long the hill might be
  6. Nov 21, 2018 at 1:19 PM
    #106
    BillsSR5
    bill
    2014 SR5
    http://i.imgur.com/Z41PkQB.gif
    jsinnard likes this.
  7. Nov 21, 2018 at 1:22 PM
    #107
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Been here six weeks, 6th time in the last year. I've seen a lot of Spain.
    Tomorrow is another workday but with the holiday its double time.
    Xmas is going to be a fucking festival at the jsinnard house this year.
    stun gun[QUOTED] likes this.
  8. Nov 21, 2018 at 1:23 PM
    #108
    seang
    TX
    17 White Off Road
    i always thought CC would do the equivalent of mashing the gas pedal. since its a DBW system, i figured the ECU handles that. then if not enough response quick enough then it would downshift. true?
  9. Nov 21, 2018 at 1:23 PM
    #109
    stun gun
    Aaronski
    Tacomas.
    Makin that scrillah!!
  10. Nov 21, 2018 at 1:30 PM
    #110
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    But with the 5th and 6th gear ratios so close together, it will bounce between gears to try and maintain speed and also bump up fuel economy. Since it doesnt know the duration of increased load or hill it might jump between trying to get to 6th for fuel economy or just maintain speed in 5th or even 4th.
    My 1st gen is also DBW but only has 1 OD gear. It's not as shifty with CC as the 3rd gen but it can get confused depending on slope / terrain.
    I didnt use cruise the first year just because of the gear changes in D, now it's almost always used with S5. Works like a champ and the revs are only 300rpm more
  11. Nov 21, 2018 at 1:37 PM
    #111
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    Yep, if not quick enough it will downshift, and with the gears being so close together, it will downshift alot.
    So take away the upshift option with S5 if it becomes annoying.
  12. Nov 21, 2018 at 1:40 PM
    #112
    ejewels
    CT
    I’m 40. I just call out bullies when needed.
  13. Nov 21, 2018 at 1:41 PM
    #113
    seang
    TX
    17 White Off Road
    interesting. must be something specific to this truck and when it thinks it needs to change gears... Id bet the TSB makes this smooth out.
    seems to be a tested fact that CC does save gas. that is, unless your ECU makes you shift like crazy for no reason.
    https://www.edmunds.com/fuel-economy/we-test-the-tips.html
    Test #3 Use Cruise Control
    Result: Surprisingly effective way to save gas
    Cold Hard Facts: Up to 14-percent savings, average savings of 7 percent
    Recommendation: If you've got it, use it.
    Using cruise control is a bit of gas-saving advice frequently on tips lists. We have always agreed with this tip in theory but we hadn't expected such significant results. First, it smoothes out the driver's accelerator input by preventing nervous "surging." Second, it makes the driver take the long view of the road rather than reacting to every change in the traffic around them.
    Method: We did this test twice with four different cars each time driving the 55-mile loop. The first time we set cruise control to 70 mph. The second time, with the cruise control off, we varied our speed between 65 mph and 75 mph. We tried to mimic the driving style of a person who is in moderate freeway traffic.
    One thing that's important to note: if you are in a mountainous area you should turn off cruise. It will try to keep you up to the speed you've set and will use a lot of extra gas downshifting to lower gears to accomplish this.
  14. Nov 21, 2018 at 1:42 PM
    #114
    BillsSR5
    bill
    2014 SR5
  15. Nov 21, 2018 at 1:44 PM
    #115
    ejewels
    CT
  16. Nov 21, 2018 at 1:45 PM
    #116
    seang
    TX
    17 White Off Road
    trying to have a serious discussion...
    BlueFalconActual likes this.
  17. Nov 21, 2018 at 1:46 PM
    #117
    jsinnard
    J
    Virginia
    16 QS DCLB OR 4X4
    You can always try it for yourself and see. For me in almost 3 yrs of ownership of this truck, CC does not help me with fuel econmy but I also average 21 mpgs per tank with a +1 tire size increase and keep the highway speeds below 70 mph with use of D and S4 and 5 at regular intervals.
  18. Nov 21, 2018 at 1:49 PM
    #118
    seang
    TX
    17 White Off Road
    is your truck's VIN on the list for the TSB?
  19. Nov 21, 2018 at 1:50 PM
    #119
    BillsSR5
    bill
    2014 SR5
