Transmission Gear Ratio Question
Discussion in 'Technical Chat' started by 10ptXtreme, Mar 9, 2015.
  1. Mar 9, 2015 at 9:56 AM
    10ptXtreme
    10ptXtreme [OP] Well-Known Member
    NJ
    2020 DCSB TRD Sport Voodoo Blue
    I'm hoping one of you technical guys (or girls) can answer this question regarding transmission gear ratios. On the 2nd gen Tacoma, the manual has a 1.00 5th gear ratio and a 0.85 6th gear ratio. The auto has the same 1.00 4th gear ratio and a 0.72 gear ratio. My question isn't about why the manual doesn't match the automatics, but why can't vehicles have 2 overdrive gears. Maybe something like:
    4th - 1.00
    5th - 0.75
    6th - 0.65
    I would think with the HP today's engines can make, they should be more than capable of having 2 overdrive gears with the second one being really tall. This would be able to give the driver better fuel economy on flat ground yet downshift to a reasonable overdrive on any incline. Thoughts?
    David
  2. Mar 11, 2015 at 10:16 AM
    10ptXtreme
    NJ
    Anybody???
  3. Mar 11, 2015 at 10:19 AM
    dakotasyota
    dakotasyota Just a Fringe of the Ging in your Minge
    Dakota
    Ellensburg, WA
    06 Access Cab, Manual, V6, 4x4, TRD Off-Road
    Total Chaos +2 LT w/ 2.5 x 8 Kings, 700 lb coils, Chevy 63s, BAMF Shock relocation, 12" King Smoothies, Locker Anytime Mod, 5% Tint All Around, 4xInnovations full skids, Custom Made Rock Sliders, 4xInnovations HC Rear Bumper w/ Tire Carrier, SOS Original Plate 2 Front Bumper, 130 w KC Slimlites, Homertaco Raptor Grill, Bestop Supertop, Smittybilt 9500 lb winch, Flowmaster 40 series, JVC deck w/ 12" Rockford Fosgate T1 in custom box, and lots more!!
    I don't know I think Toyota would have done much better with a taller overdrive. .85 isn't enough. But I think .65 would be pretty crazy... we don't quite have that much horse power
  4. Mar 11, 2015 at 10:57 AM
    10ptXtreme
    NJ
    0.65 was just a number I threw out there. But then again, on a nice flat or downhill section, maybe it might be possible. After all, the auto version uses a 0.72 gear so 0.65 doesn't see that far off.
    I would think that some engineer could figure that out though.
    David
  5. May 19, 2015 at 12:40 AM
    tubesock
    tubesock Well-Known Member
    A bit of a thread necro but it seems like an interesting question. There's no physical or engineering limitation that prevents a transmission from having more than one overdrive gear. For example, this 8 speed auto that appears in the Dodge Ram and other vehicles has 2 overdrive ratios http://en.wikipedia.org/wiki/ZF_8HP_transmission.
    It boils down to a trade off between having a limited number of gears and the purpose of the vehicle. In automatics, more gears means more complexity, weight, and cost. It isn't necessarily simple to just add another gear. This is also true of manuals but I think more importantly, no one wants to have to row through more than 6 gears.
    I suspect that because the Tacoma is rated to tow up to 6500lbs there isn't room for two overdrives. It needs to be geared appropriately to haul that load around without obliterating the clutch or otherwise being useless on hills. People complain about the extra short 1st gear on the 6 speed and I suspect it is designed that way to make it easier to get a maximum load going on an incline. On the automatic they can get away with a taller 1st gear because the torque converter will absorb some punishment during dead-stop acceleration with a max load as long as it has a transmission cooler.
    Even with those constraints in mind, I think there is still room for improvement on the 6MT gear ratios. I'm interested to see how things shake out in the next generation. also try reading this thread for more exciting gear ratio discussion. https://www.tacomaworld.com/threads/rear-end-gear-ratio.272346/
    TRDSport10 likes this.
  6. Jun 9, 2015 at 11:52 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
    I had an 00 WS6 TransAm with a MN6. 6th was very tall turning only 1300 RPM at 70. It had gobs of low end torque which allowed it to accelerate up hills in 6th or maintain speed with cruise control on. My truck hunts on small hills in 4th. I don't think these trucks produce that type of power down low in the rpm range to really take advantage of such a tall gear. That and they are about as aerodynamic as a barn door.
