Transmission Gone?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Bigmikelakers, May 1, 2016.
  1. May 1, 2016 at 4:17 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    I think you need to learn how to properly 'Quote' here on TW....... Your post and quote has my name, but that is not at all what I wrote.
    Where did you get that quote from?... they're not my words.
  2. May 1, 2016 at 4:17 PM
    fxntime
    fxntime Well-Known Member
    2015 Tacoma off road TRD and 2014 FJC
    Grinding, probably the rear end, less likely transfer case, not transmission.
    asuchemist likes this.
  3. May 1, 2016 at 4:18 PM
    FlyFisher1
    FlyFisher1 Well-Known Member
    NJ
    My apologies...not sure how that happened
    File IFR[QUOTED] likes this.
  4. May 1, 2016 at 4:21 PM
    File IFR
    Central MA
    No prob bro. :cheers:
    I've done it once too :oops:
    FlyFisher1 likes this.
  5. May 1, 2016 at 4:27 PM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Unfortunately once you run transmission with low fluid to the point you can feel it, its done deal.
    Not a question "If its going to fail?" but "When its going to fail?"
    Lucky for you it failed within warranty. Others will probably get a failure after warranty expires.
    I would not buy used 2016 Tacoma, because transmission is a time bomb.
    Lucky for you yours blew up with in warranty, so you will get it fixed.
    tomwil likes this.
  6. May 1, 2016 at 4:36 PM
    gearcruncher
    Canadain bumper technician
    I will take a guess at a broken planetary inside the transmission . This would cause the output speed sensor to trip a code forcing the transmission into limp mode .
    A new production transmission has weak points that Toyota doesn't compensate for during testing . Toyota is more concerned with fuel economy over durability/ reliability these days
    Chances are , the OP will never know the true cause or the justification of driving with low fluid
    Dealerships dont disassemble transmissions . They just replace .
    Gatordog, Simon's Mom and dutchjim like this.
  7. May 1, 2016 at 4:39 PM
    Bigmikelakers
    Bigmikelakers [OP] Well-Known Member
    Los Angeles
    '16 DCSB OR
    I'm pretty sure it's low transmission fluid because I got a "overheated transmission warning" before it went into limp mode. I dropped it off at the dealer. Going back tomorrow to get my rental (better be free) and find out what's up. I'm not even mad. I'm glad I had problems while it was under warranty.
    MadDaddy and gearcruncher like this.
  8. May 1, 2016 at 4:41 PM
    Joe D
    Joe D .
    You and I (or maybe someone else & I) have debated this issue before I believe. I understand and I don't necessarily disagree with the logic...the rub for me is buying and paying a premium for new and then being provided a reman unit. IMO, if he's given a reman unit, the only fair resolution from TM is to provide some other type of compensation in addition to the repair itself.
  9. May 1, 2016 at 4:42 PM
    gearcruncher
    I agree with you . At least it happened under warranty .
    There were many folks who were not so lucky with their 2nd gen trucks who suffered from low fluid issues and didnt know it until warranty had expired
    If your trans temp light illuminated , your transmission had to hit 305 degrees . Your fluid is definitely cooked
  10. May 1, 2016 at 4:51 PM
    Joe D
    Joe D .
    I guess it's a relative thing. But, did you compare the number of tranny complaints to that total of 20 on the Tacoma? Did you find how many complaints were placed on other 2016 Toyota models?
    Here's what I base my feelings on...
    A.) The portions of transmission complaints is a large percentage of those 20.
    B.) There are ZERO (0) total complaints for 2016 Toyota 4Runners, 5 total for 2016 Highlanders and 8 total for 2016 Tundras. Those three models, in total, far outsell the Tacoma and have few complaints.
    And so, as I stated in my post you quoted, "if it means anything"...it does to me if I'm in the market and it constitutes a boat load (if only to me).
    File IFR likes this.
  11. May 1, 2016 at 4:52 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I'm not thinking its the planetary gear assembly. When that goes, you definitely get a "bang", but you also don't go anywhere. You gently coast to a stop.
    You are correct. We most likely will never know what the real problem was.
    gearcruncher[QUOTED] likes this.
  12. May 1, 2016 at 4:54 PM
    koditten
    Kirk
    Central Michigan
    You need to take into account how many Tundra's and Highlanders that are sold compared to the Tacoma. I don't know the actual number, but I know there are way more Tacoma's being sold compared to the others.
  13. May 1, 2016 at 4:59 PM
    Joe D
    Joe D .
    I did...
    For the last reported month:
    Tacoma ~ 17k
    Highlander ~ 15k
    Tundra ~ 11k
    4Runner ~ 10K
  14. May 1, 2016 at 5:02 PM
    FlyFisher1
    NJ
    I didn't look into it that far..I just searched for all 2016 Tacoma complaints and saw 20 total. I was expecting to see a lot more than that.
    Joe D[QUOTED] likes this.
  15. May 1, 2016 at 5:12 PM
    #35
    gearcruncher
    We could diagnose all night and still never know .
    What we do know
    He was driving at highway speed as the transmission was upshifting and the temp light illuminated , most likely 5th gear . He heard grinding , then the transmission downshifted ( went into limp mode ) .
    The only six speed I can think of that is comparible at this time with a you tube video is the 6 speed AS69RC Aisn Seiki in the dodge . Have a look at the overdrive reaction gear. The splines look incredibly weak .If the splines fail , the first thing you usually hear is a grind .
    Like I say , its a guess :)
    https://www.youtube.com/watch?v=sFEyQGD0B-E
    arkywally likes this.
  16. May 1, 2016 at 5:12 PM
    #36
    FlyFisher1
    NJ
    Just for S&G's.... there are 11 complaints for F150 and one guy said he's allergic to the truck lol
    Joe D and bulldog like this.
  17. May 1, 2016 at 5:24 PM
    #37
    arkywally
    arkywally Well-Known Member
    David
    2016 DCSB TRDOR
    ICON Stage4 285/70/17 Cooper STT Pro Method NV
    And beat the shit out of it like a rental....
  18. May 1, 2016 at 5:45 PM
    #38
    senayski
    senayski Well-Known Member
    Pittsburgh, PA
    Automatic?
  19. May 1, 2016 at 5:51 PM
    #39
    Joe D
    Joe D .
    Better be based on how he discribed it up shifting.
    senayski[QUOTED] and koditten like this.
  20. May 1, 2016 at 5:58 PM
    #40
    arkywally
    David
    2016 DCSB TRDOR
    What ever happened to all the gear heads from the early days who could tear down a tranny or work on somebodies rear end? (ok, just for this thread, in and out of the shop) it was a special breed then and now, you got my attention.
    I can relate this to the real computer technicians of the 70's early 80's compared to all thereafter....
    Gotta respect those in the know...
