transmission grinding
Discussion in '1st Gen. Tacomas (1995-2004)' started by noahpadilla, Apr 17, 2024.
  1. Apr 17, 2024 at 5:50 AM
    noahpadilla
    noahpadilla [OP] New Member
    noah
    99 tacoma 3.4 4x4 manual
    can anyone help me out? been dealing with this for about 3 weeks now. i just changed my clutch and changed my transmission. still getting a grinding sound in 3rd and 4th gear. 1st and 2nd gear just vibrates my truck like a 9.0 magnitude earthquake. anyone know why it sounds like my transmission is grinding?
  2. Apr 17, 2024 at 5:59 AM
    oldtimertoyota
    oldtimertoyota Well-Known Member
    New Mexico
    2009 4X4 Double Cab-1986 2wd Pickup Orig own
    It’s going to be hard to say with changing the transmission and clutch at the same time, usually one or the other has issues. Was your transmission having issues before that were different from what’s going on now? Did you replace your transmission with a rebuilt one or one from a junkyard?
    noahpadilla[OP] likes this.
  3. Apr 17, 2024 at 6:08 AM
    noahpadilla
    noah
    the same thing has been happening before i changed both transmission and clutch. so i figured if i changed everything the problem would go away lol. to answer your question i bought it rebuilt from a junkyard
    oldtimertoyota likes this.
  4. Apr 17, 2024 at 8:49 AM
    oldtimertoyota
    New Mexico
    Seems crazy to have such similar things happening to both. Hopefully someone else has some ideas of what’s going on with your truck
  5. Apr 17, 2024 at 9:03 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    Did you resurface/replace your flywheel?
  6. Apr 17, 2024 at 6:43 PM
    noahpadilla
    noah
    no i never. my flywheel looked fine so i didn’t think anything of it.
  7. Apr 18, 2024 at 9:22 PM
    time623
    time623 Well-Known Member
    James
    AZ
    1995.5 White Tacoma 4x4
    Just to clarify everything:
    You get massive vibrations in 1st and 2nd
    And you get grinding noise in 3rd and 4th
    So there’s no grinding in 1/2 and no vibrations in 3/4?
    Is 5th gear normal?
    Are the grinding noises during shifting or the whole time, and are both the noises and grinding RPM dependent?
    And you already replaced both the clutch and the entire transmission, but neither changed anything.
    btu44 and noahpadilla[OP] like this.
  8. Apr 18, 2024 at 9:25 PM
    noahpadilla
    noah
    correct. 5th gear grinds too. it grinds in 1st and 2nd just not as bad. it’s hard to explain
  9. Apr 20, 2024 at 7:07 AM
    NC Gazzer
    NC Gazzer Well-Known Member
    Durham, NC
    1996 Tacoma 4wd 2.7 + 2023 TRD Sport
    I think you need to widen your problem search: Brakes? Axles, Driveshaft?
