Transmission hardlines?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by deanosaurus, May 30, 2022.
  1. May 30, 2022 at 11:42 AM
    deanosaurus
    deanosaurus [OP] Caveman
    Northeast Region
    09 TRD OR AC
    I found a pinhole ("fixed" with jbweld for now) in what I think is the return line for the transmission in my 2009.
    I'm speaking of the hard lines coming out of the side of the AT housing.
    I've never had to replace them before - are the fittings and lines a standard size and diameter? Is stainless replacement a thing? Failing that, does anyone have part numbers for the factory fittings and lines?
    Thanks!
  2. May 30, 2022 at 11:46 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    deanosaurus[OP] and Jimmyh like this.
  3. May 30, 2022 at 11:51 AM
    Fullboogie
    Fullboogie Well-Known Member
    Dave
    Houston
    2007 Prerunner & 2008 4Runner
    In a pinch you could always cut out the bad section of line with a tubing cutter, flare the ends of what remains, and use trans hose in between. In short, make a patch.
