Transmission help! Did I get stealershipped? https://ibb.co/tXCfWkY
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jake8901, Jun 1, 2023.
  1. Jun 1, 2023 at 10:32 PM
    Jake8901
    Jake8901 [OP] Member
    Jake
    2012 4.0 4x4
    2012 4x4 4.0 200k miles
    Hey everyone. Just had a flush done at a dealer. I know I shouldnt have waited 200k but anyway. Even though I've changed oil 10x, in a hurry last night night with headlamp accidently drained about 1qt out of the trans before i realized, the day after a flush! Kicking myself. sounds like I'm not alone
    If that image shows up, does that look like a flush could have been done? Drove about 1hr since flush. Left is out of the overflow plug, right is brand new atf4.
    couple questions, what fluid would dealer have used? I assume it should all be bright red, to me, it doesn't look like a damn thing was done.
    Can I top off with atf4 or should I get some toyota atf from dealer? Is atf4 best to use?
    I really don't think I drained any more than 1 qt, danger to drive on? Was planning on just adding 1 qt and doing the diy temp check protocol.
    Any help appreciated, need truck badly this weekend for a side job
    Hi everyone, i have a 2012 4x4 4.
  2. Jun 1, 2023 at 10:59 PM
    Ricardo13x
    Ricardo13x YT: @UrbanOpsOffRoad IG: @urban.ops.offroad
    Upland, CA.
    05 OR DCSB ProRunner(4x4 conv.), Chevy 63”s, NWF EcoCrawler, 35”s
    Random stuff. Oh! and converted to non ADD 4x4.
    Stop it with the bot BS.
  3. Jun 2, 2023 at 6:01 AM
    Jake8901
    Jake
    2012 4.0 4x4
    Dude it's not a bot, that url in title is a url link I uploaded with a sample of trans oil after a "flush" and brand new atf4
  4. Jun 2, 2023 at 6:04 AM
    $yoda$
    $yoda$ Well-Known Member
    Tom
    2007 Tacoma 4.0
    2.5 inch lift, 285/75r16s, upgraded stereo system, Magnuson mp90 supercharger system.
    Just post the pictures.
    SR-71A likes this.
  5. Jun 2, 2023 at 6:19 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    URL doesn't work, says bad gateway.
    2nd gen V6 uses Toyota WS. Mixing with ATF Type IV would probably cause issues long term. It's doable as a temporary measure, but then you'd need to flush the system again at an expense. If it's your only vehicle, I'd suggest getting a ride to the dealer to pick up WS fluid.
  6. Jun 2, 2023 at 7:02 AM
    Jake8901
    Jake
    2012 4.0 4x4
    Sorry couldnt figure out how, thought it needed url, heres after flush sample on left after 1 hr drive. Right is new fluid
    Just picked up some atf ws
  7. Jun 2, 2023 at 7:03 AM
    Jake8901
    Jake
    2012 4.0 4x4
    On 2012 do you replace through the cooler lines up by radiator? See. 2 different things for 2012
  8. Jun 2, 2023 at 7:13 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Why in the hell do you have 5 billion blank lines in your first post????
    Use Toyota WS or Valvoline MaxLife ATF. Fill from the side fill port, check level via the proper temp check procedure & the Check port on the pan. Lastly color is not a good indicator of ATF life
  9. Jun 2, 2023 at 7:19 AM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Looks like they likely just did a pan drain and fill, should be a lot lighter if a full flush was done. Top it off with Toyota WS or anything that says it meets Toyota WS specs. Many people use the Valvoline previously mentioned, or I have used Castrol Transmax Full Synthetic Multi-Vehicle ATF.
  10. Jun 2, 2023 at 7:34 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    I agree with tenbeers,looks like they only did a drain and fill. Check your paper work,how many litres of oil did they charge you for? If they only did a drain and fill ,learn to do it yourself and do a few more over the course of a week or two. Each time you do note the colour of the fluid coming out might be a good indicator of fluid quality. Good luck
  11. Jun 2, 2023 at 11:47 PM
    TacoTuesday1
    SD CA
    You have no way to know.
    Fresh fluid has cleaning detergent and will quickly discolor put into the trans.
    the fluid in the picture does look replaced.
    working as a mechanic we did not have a flush machine for trans. It was drain and fill. Which is still good.
    The idea is that flushing means kicking up any harmful wear debris that has settled, making it circulate in the trans.
    there is rarely a reason to not do this yourself. Or get to know a trustworthy person to do it.
    Exceptions I can think of are welding. Most people don’t know how to weld.
    SR-71A likes this.
