Transmission issue or normal?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dan2731, Oct 31, 2022.
  1. Nov 1, 2022 at 5:03 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Just the revving and TW members reporting when the 3rd Gen first arrived with a transmission cooler the factory was under filling them. Dealer checked and filled it under warranty.
  2. Nov 1, 2022 at 5:23 PM
    Dan2731
    Dan2731 [OP] Well-Known Member
    Dan
    2022 Army Green DCLB Sport
    Sweet, Thankyou. Will call and have them check the fluid level while they have it for the Child Anchor Recall.
  3. Nov 1, 2022 at 9:14 PM
    TA2016
    Oregon
  4. Nov 2, 2022 at 3:54 AM
    Dan2731
    Dan
  5. Nov 2, 2022 at 4:22 AM
    TA2016
    Oregon
  6. Nov 2, 2022 at 5:28 PM
    Dan2731
    Dan
  7. Nov 2, 2022 at 7:06 PM
    TA2016
    Oregon
    Since my 2016 had a software update in 2017 and the OP on the above thread needed his 2019 to get different software update, it doesn't hurt to ask about a TSB for a 2022.
  8. Nov 3, 2022 at 5:54 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    All i can comment on this was my 2020 3.5 auto already had the update when i picked it up. I would assume a 2022 would also.
    TA2016[QUOTED] likes this.
  9. Nov 3, 2022 at 9:18 AM
    G2.M6
    G2.M6 Well-Known Member
    Fort Collins CO
    1980 Toyota Truck MT "shifty" 1981 Toyota Truck "little orange" 2023 Solar Octane MT "Solaris"
    A few, mainly added skids. I like leaving the suspension alone. I drive forest service dirt roafs in the desert west extremely extremely too fast. Toyota nailed this suspension going 65 across desert terrain. Changing it is dumb unless you have a specific need like crawling or mud.
    Insert obligatory smart ass manual transmission comment.
    :mudding:
  10. Nov 4, 2022 at 11:47 AM
    harbrown
    harbrown Well-Known Member
    Harold
    Daphne AL
    2016 Tacoma Off Road 4x4
    Same here guys, same here, 2016 just started doing this about a year ago. i change (drain and top off according to proper procedure) trans fluid every 25k , may mess with the fluid levels to see. Also, mine only does this when its cold. if all systems really hot then no issue. probably a fluid issue. 134k miles BTW.
  11. Nov 4, 2022 at 12:04 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    mine does that, i wait for it to lock up before giving it gas.
  12. Nov 6, 2022 at 4:56 PM
    Dan2731
    Dan
    After looking deeper into mine i think it’s just in “Low” and sometimes rolling too fast to notice power. Still gonna get the fluid checked next time i’m at the dealer. 6 hour trip today and it was fine
  13. Nov 7, 2022 at 6:02 AM
    clownkillerloaf
    clownkillerloaf Well-Known Member
    Logan
    2025 SR 4X4 DCSB
    nice. Sounds like a non-issue, hopefully is. Not sure if you wanna avoid the dealer appointment and runaround, but you can check it yourself FWIW. Its pretty simple
  14. Nov 7, 2022 at 6:17 PM
    Dan2731
    Dan
    Yeah you’re probably right about the run around. My trucks affected by the child seat anchor recall so will probably get that done and was gonna ask them to check while they had it but i haven’t been able to get a hold of them.
  15. Nov 7, 2022 at 7:20 PM
    #35
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    the chisel recall. they hit your welds with a chisel to check the integrity...:sawzall:
  16. Nov 10, 2022 at 1:24 PM
    #36
    Dan2731
    Dan
    Yes sir, already failed the chisel test! According to them my recall was done but haven’t been able to get ahold of anyone useful..
  17. Jan 10, 2023 at 2:05 PM
    #37
    Dan2731
    Dan
    Had them check it today. Said they replicated the “issue” with the scan tool hooked up and it’s doing everything it should. Also said they checked the fluid and it’s spot on. They still have my truck for the seat anchor recall so i’ll ask more tomorrow.
