Transmission issue
Discussion in 'Technical Chat' started by Which Way Out, Jun 17, 2021.
  1. Jun 17, 2021 at 3:17 PM
    Which Way Out
    Which Way Out [OP] Well-Known Member
    Bill
    Santa Barbara
    2002 Tacoma 4 Door Prerunner
    I have 217,000 + miles on mine. 2002 pre runner V6 2WD
    Was working well until I towed a small trailer almost 900 miles to the Eastern Sierra.
    Now it has a shutter in high gear when you try to accelerate.
    Anyone else ever have these symptoms ever?
    Taking it to Aamco Friday around 11 a.m to check it out.
    What should I be worried about.?
  2. Jun 18, 2021 at 5:41 AM
    Rambo MARINE Recon
    Rambo MARINE Recon Well-Known Member
    Robert Goudin
    2013 Toyota Tacoma PreRunner DCLB V6 Auto. Hvy Duty
    Many, suspension, Hood Scoop,Decals and Pin Stripping, New Tires Michelens LTX MS2
    Torque Converter maybe?
    Robnik likes this.
  3. Jun 18, 2021 at 5:45 AM
    Robnik
    Robnik Disciplined Maniac
    Rob
    Greenacres, Florida
    2012 Base Reg Cab 2.7L 2TR-FE A340E
    That's a lot of miles, probably a rebuild. Don't let them overcharge you! Good luck.
  4. Jun 18, 2021 at 5:55 AM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    Have them inspect that driveshaft really good. You may have carrier bearing issues. Actually, thinking more about it, it sounds exactly like a carrier bearing issue.
    Sprig likes this.
  5. Jun 18, 2021 at 9:40 AM
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    This ^^^. Also I’m wondering if you over heated the tranny when you towed the trailer 900 miles. Over heating the fluid could cause lots of problems.
    12TRDTacoma[QUOTED] likes this.
  6. Jun 18, 2021 at 9:55 AM
    Which Way Out
    Bill
    Santa Barbara
    The fluid looks good. I had it changed last year and still looks fresh, no bad smells whatsoever. Radiator was replaced 2 years ago and never rose above mid point on any part of the trip.
    Just got home from a shop to have the rear trans mount replaced, but the wrong part was shipped and we weren't able to change it. Center driveshaft bearing looks good and I didn't notice any weights missing on the driveshaft.
    Have a 11 a.m appt at AAmco to inspect. Wait and see what they say.
  7. Jun 18, 2021 at 2:36 PM
    Which Way Out
    Bill
    Santa Barbara
    Well the report on the transmission is..................
    It seems to be fine.
    So what could it be. No codes or check engine light on. But it just started to occur last Sunday and only really shows up in high gear and when you accelerate, then it shudders a little and has a lack of power.
    The shop says its most likely one coil pac or plug not working well under load. I think I tend to agree, as the idle is a bit rough recently.
    Checked a few you tube videos and it looks fairly straight forward change out
    So, OEM off of Amazon ? Any one have any history with that? And any pit falls to look out for?
    TIA
