Transmission issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Ramsey35, Jan 16, 2019.
Thread Status:
Not open for further replies.
  1. Jan 16, 2019 at 6:21 PM
    Ramsey35
    Ramsey35 [OP] Member
    2018 Tacoma Trd sport
    Leveling kit and 33” tires
    Why does my 2018 Tacoma automatic feel like it starts off in third fourth or fifth gear half the time? It drives and responds much better when I use the manual shift mode
  2. Jan 16, 2019 at 6:24 PM
    Clearwater Bill
    Billy
    Largo Florida
    If youll use the search feature and read all the threads, we'll see you back around the time school is out.
    Nutshell. Take it back and complain.
    And no, there's still no SC for the 3.5
    doublethebass and Joe23 like this.
  3. Jan 16, 2019 at 6:24 PM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    Software update. Tsb
    Makes a huge difference
    Flash1034 likes this.
  4. Jan 16, 2019 at 6:26 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    turn on ECT. problem solved. then you will need to get the mod 'ECT on at startup" and you will be all set.
  5. Jan 16, 2019 at 6:29 PM
    IRISHFAN
    IRISHFAN Well-Known Member
    Jeff
    SE Pennsylvania, Elverson
    2019 Tacoma TRD Sport DCSB 4X4 M/T Cement Gray.
    Stock
    Unless your regeared those 33’s aren’t doing you any favors in the performance area.
    kahanabob and 2016Tacoman like this.
  6. Jan 16, 2019 at 6:32 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    Yup, compound the already bad pairing of the 3.5 with the automatic trans and add your 33s and you got yourself a bad mix.
    As stated above, your only fix is to regear
    kahanabob and IRISHFAN like this.
  7. Jan 16, 2019 at 6:34 PM
    TeeYoda
    TeeYoda Well-Known Member
    PNW
    2003/2025 Tacoma sr5 4x4
    Good Gawd man! Are you just trolling? This subject has been beaten to death on this forum. The "search" function is your friend.
    2016Tacoman likes this.
  8. Jan 16, 2019 at 6:35 PM
    HTOWN4X4
    HTOWN4X4 Well-Known Member
    2017 DCSB MGM 4X4
    TSB
  9. Jan 16, 2019 at 6:37 PM
    TacomaSport86
    TacomaSport86 2010 Tacoma/2016 4Runner Pro
    3.5 and auto transmission in this truck is no bueno
    kahanabob and shakerhood like this.
  10. Jan 16, 2019 at 6:39 PM
    Dragracer_Art
    Dragracer_Art Tundra for the win
    GA
    2020 Tundra Crewmax 4x4
    Mine runs much better after the TSB 62-18 update.
    I use ECT and S4 most of the time. Only get into S5 if im at 70+ mph
  11. Jan 16, 2019 at 6:40 PM
    kullin
    kullin Well-Known Member
    Scott
    Denison Tx..
    2015 Toyota double cab
    None Yet :)
    My Trans is fine....
    LivinOnEdge likes this.
  12. Jan 16, 2019 at 6:43 PM
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    I have 0 issues with my automatic. Just as fast as 2nd gen in 0-60 if not a tad faster and passing times once in the higher rpm are insane, much faster than 2nd gen.
    I really don't understand all these complaints.
    HTOWN4X4 likes this.
  13. Jan 16, 2019 at 6:44 PM
    SgtPuddin
    SgtPuddin Well-Known Member
    Mississippi
    2018 Tacoma TRD Off-Road DCLB
    KO2 Ray10 5100’s 884’s Rx350 Retro Headlights
    0 issues here. It’s a truck not a Lamborghini.
  14. Jan 16, 2019 at 6:47 PM
    StayinStock
    Bob
    Missouri
    Yes I do
    Some
    Welcome to TW!
  15. Jan 16, 2019 at 6:50 PM
    tjpratt
    tjpratt Well-Known Member
    Travis
    Aurora, Colorado
    2016 Limited 4X4 Tacoma
    3.75" Lift / OME OVTuned
Thread Status:
