Transmission issues
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Zipper24, Mar 17, 2021.
  1. Mar 17, 2021 at 9:17 AM
    Zipper24
    Zipper24 [OP] Member
    I recently purchased a new tacoma. When i start it when it is cold i put the transmission in gear and it takes a few seconds to actually engage. For example i will put it in reverse and the engine drops to 6k rpm but when i take my foot off the brake it goes to about 11k rpm and then the transmission engages and the vehicle lunges. I took it back to the dealer and he said they all do that. I am very skeptical
  2. Mar 17, 2021 at 9:22 AM
    naked farmer
    naked farmer Well-Known Member
    Nor Cal
    ‘17 B.Red Off Road
    go back and tell him you’d like to get in one on the lot and try it
  3. Mar 17, 2021 at 9:23 AM
    ryanvar42
    ryanvar42 Well-Known Member
    2024 Silverado Trailboss
    None
    yup I would do what naked farmer said
    Zipper24[OP] likes this.
  4. Mar 17, 2021 at 9:31 AM
    Silentshredr
    Silentshredr Well-Known Member
    Chuck
    16 DclbOr4x4
    I wouldn’t do anything a naked farmer told me to do, just saying.
  5. Mar 17, 2021 at 9:34 AM
    Nyneuro
    Nyneuro Well-Known Member
    James
    2019 Tacoma
    none
    Thats not normal. Maybe low fluid?
    Dad's Saturn did that in reverse. Engine lockup finally killed the car not tranny
    Skydvrr likes this.
  6. Mar 17, 2021 at 9:35 AM
    ryanvar42
    None
    I bet you it is and hes paranoid because there is always a lag from selecting the gear and for it to acutally happen which cold be a second or two. If I am in drive and stopped and switch to reverse it is not instant. Might be a second or two to engage and then I go. Same for every vehicle I have ever driven
  7. Mar 17, 2021 at 9:44 AM
    Zipper24
    Im not talking about a lag when you first put it in gear, it actually jumps in and out of gear after that and lunges
  8. Mar 17, 2021 at 9:50 AM
    piff
    piff Well-Known Member
    Minnesota
    2019 Quicksand Tacoma TRD OR DCLB AT
    Bone stock baby
    Found your problem OP!!!!
    In all seriousness, doesn't quite sound right. Without video it's hard to diagnose via interwebz but I would try another dealer if the current one is being difficult. naked farmer had a great suggestion. push comes to shove get in contact with dealership owners / toyota corporate. squeaky wheel getting grease or something idk.
  9. Mar 17, 2021 at 9:53 AM
    naked farmer
    Nor Cal
    ‘17 B.Red Off Road
    Best fun is being naked running backwards through a corn field.
  10. Mar 17, 2021 at 9:55 AM
    sicki
    sicki Well-Known Member
    your problem is shifting at 6K rpms, and blowing your motor at 11k hahha
    BMH likes this.
  11. Mar 17, 2021 at 9:56 AM
    naked farmer
    Nor Cal
    ‘17 B.Red Off Road
    I’ve had a few incidents where my truck lunges in reverse, but the reverse gear went in just fine though.
  12. Mar 17, 2021 at 9:56 AM
    T-yoda
    T-yoda Well-Known Member
    Dave
    Eastern pa
    17 TRDORDCLB mgm
    265-75-16 BFG AT, firestone riderites
    Or maybe an 11k runathon in a thong!!
  13. Mar 17, 2021 at 9:57 AM
    ryanvar42
    None
    Yeah mine does that too if I don't hold the brake firmly down. Esp if its cold
    Zipper24[QUOTED][OP] likes this.
  14. Mar 17, 2021 at 10:00 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I hate trannys that don't do what they're told.
    Maybe @gearcruncher has some beta.
    I too, vote low fluid.
    CT Yankee and Zipper24[OP] like this.
  15. Mar 17, 2021 at 10:04 AM
    racegkrueg
    racegkrueg Well-Known Member
    Fresno, CA
    '18 DCSB TRDOR White
    This is totally normal. The truck high idles while below operating temps in neutral and park. High idle should be at about 1100 rpm. When you put the truck in gear it will drop to a normal idle of about 600. Once the truck is at temp it will idle at 600 in park and neutral. Because of the high idle, when you drop it into gear it may lurch a bit if you don't have your foot on the brake.
    Edit: never mind. I read your post a bit better and saw it drops to 600 and then lurches after you let go of the brake. My mistake. Doesn't sound normal to me.
  16. Mar 17, 2021 at 10:04 AM
    BMH
    BMH Well-Known Member
    Bruce
    Pend Oreille County, WA.
    2020 4x4 SR AC 2.7 liter - Bare Bones Base Model
    you beat me too it....
  17. Mar 17, 2021 at 10:20 AM
    Zipper24
    My error its 600 and 1100 rpm
    Skydvrr likes this.
  18. Mar 17, 2021 at 10:28 AM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Happen all the time or only when the engine is cold?
  19. Mar 17, 2021 at 10:28 AM
    Zipper24
    Thank you all for your help i really appreciate it.
  20. Mar 17, 2021 at 10:30 AM
    Zipper24
    Just happens when its cold
