Transmission issues
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jdcarsguys, May 18, 2025.
  1. May 18, 2025 at 5:14 PM
    Jdcarsguys
    Jdcarsguys [OP] New Member
    Jonathan
    01 gold tacoma
    Sorry for post. I’ve never posted on a forum before. But I’m at a complete loss on this truck. 2001 3.4 Tacoma with auto trans and 216k miles. I’ve had nothing but issues since buying the truck. Latest problem is randomly truck won’t shift out of first gear. Truck could drive great for 2 weeks, or it could mess up first thing. I’ve done a neutral safety switch, throttle position sensor, and flushed trans. I’m thinking it’s the solenoids maybe. Wondering if there might be a way to test that theory out. Pretty knowledgeable with cars. But this is my first Toyota.
  2. May 18, 2025 at 10:35 PM
    Glamisman
    Glamisman Well-Known Member
    First thing to do if you are mechanical in nature is to check the trans fluid level/condition. Next is to drain the trans pan and look for glitter in the fluid. If there is glitter, put her back together because she is done. See if she will start out in second gear, put the gear selsctor in "2" and see if is in 2nd, you can tell because the truck wont have that much pull away power. When she does run normal are the shifts regular or are they late and hard or early and soft.
  3. May 19, 2025 at 1:59 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    Check ALL of the wiring for shorts. I've had mice chew insulation off wires causing them to short. The car would drive great at times, but if the wire made contact with something then the transmission would do all sorts of funky stuff. Was getting codes indicating the transmission was in need of a rebuild.
    I dropped it off at a transmission shop for a $2000 rebuild. They called me 30 minutes later and told me to pick it up, they fixed it. Before pulling the transmission, they found the exposed wire and repaired it. They charged me 1/2 hour labor ($50) and it was still working great 5 years and another 100,000 miles later until a distracted driver rear ended it at a traffic light and totaled the car.
    MalinoisDad likes this.
  4. May 19, 2025 at 7:11 AM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  5. May 19, 2025 at 7:21 AM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    Thats a good shop worth naming! They didn't snake you for the unnecessary $2000 rebuild.
  6. May 20, 2025 at 8:53 PM
    S14Jimbo
    S14Jimbo New Member
    J l M B O
    '96 BLK Xtracab LX
    LEDs and 31's
    Had this same issue last month. Turns out the fluid in the trans was burnt, low, and the pan had tiny shards of metal in them. Did a proper flush and cleaned the screens. Runs tits now.
    96 3.4 auto 4x4
