Transmission just started lagging after 55K...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kenny650, May 1, 2010.
  1. May 1, 2010 at 10:19 PM
    Kenny650
    Kenny650 [OP] Well-Known Member
    I've searched this and it seems as though only the newer Tacomas are getting a tranny lag. Mine just started lagging ever since I hit 55,000 on the odometer - WTF.
    I slow down and when I accelerate again it takes a bit for it to kick into gear. Is this the so called transmission lag?
  2. May 1, 2010 at 10:31 PM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    What do you mean by "kick into gear"? Are you talking about it taking longer to shift, or it is very slow to get up to speed?
    I notice that my truck does some weird stuff with shifting from time to time, you could try taking it in to get the trans flashed.
  3. May 1, 2010 at 10:45 PM
    Kenny650
    It's taking longer than usual to shift. It revs up pretty high then kicks into gear and lurches forward. It's getting annoying.
  4. May 1, 2010 at 10:52 PM
    BakoTruck
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Don't know what to tell you, could be a problem with the torque converter, or the trans. All I can recommend is getting the trans flashed, and also doing trans oil change, since you are getting close to the recommend time to change. 60,000-70,000 miles I believe is the recommend time from Toyota.
    Sorry I wasn't much help, but hopefully someone else has some ideas to add on what it could be.
  5. May 2, 2010 at 4:10 AM
    Fortech
    Fortech Well-Known Member
    CANADA
    2005 Toyota Tacoma TRD OR
    Bilstein 5100's, rear TSB, Firestone bags
    I would try a drain and fill of the pan. At least once completed you will know the ATF level is at the correct level.
