Transmission lag in 09' - update
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JPinCowtown, Jun 15, 2009.
  1. Jun 15, 2009 at 6:52 AM
    JPinCowtown
    JPinCowtown [OP] Well-Known Member
    Texas
    09' SR5 4x4
    Or non-update, because I learned nothing new. I took it into the dealer for it's first oil change and told them about the annoying transmission lag when it tries to upshift after coasting at slow speeds. The two service guys looked at each other as if to say "well, here we go again". They checked it out and said they could find nothing wrong but did say that at least half of the 09's sold at that dealership have come back asking about the same thing. He didn't try to sell me the " the computer is learning your driving habits" theory that some of you have heard. He just said it is a characteristic of that transmission. That's just great. Guess I'll just have to get used to it.
  2. Jun 15, 2009 at 7:38 AM
    Captain
    Captain Well-Known Member
    nys, Hudson Valley Area
    09trd sport pkg d/cab LB
    My new (4500) miles, 09 has the same issue. Just trying to get used to it. Let me know if you ever hear of a fix for this. Thanks
  3. Jun 15, 2009 at 7:43 AM
    techgeekwill
    techgeekwill Captain Funk
    Spring, TX
    09 Tiberland Mica DC LB
    I've got about 4300 on my 09, not noticing the problem. Then again, I haven't really been looking for the problem either.
  4. Jun 15, 2009 at 7:56 AM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    I run my '08 in 4th instead of "D" and it seams to be much more responsive in town. It really seems to keep shifting to a lesser amount. Other than that I dunno.
  5. Jun 15, 2009 at 8:06 AM
    STLTaco09
    STLTaco09 Well-Known Member
    5100's all around, fronts at 1.75". TSB leaf pack + Toytec TSB AAL
    I've got almost 7500 miles on mine. I don't really notice this issue.
  6. Jun 15, 2009 at 8:08 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    My 07 shifts perfectly......Im not sure what the difference is between the years, but there shouldnt be an issue like this.....
  7. Jun 15, 2009 at 8:14 AM
    kmann6905
    kmann6905 Active Member
    Pennsylvania
    Tacoma 4x4 TRD
    I have 1700 miles on my 09 and noticed this when pulling into my street which is a downward grade. As soon as I complete the drift around the corner and begin to accelerate downhill there is a momentary lag for the transmission to catch up with the drift. I write this off to driving a truck and not a SUV.
  8. Jun 15, 2009 at 8:50 AM
    LiftedForLife
    LiftedForLife Active Member
    Massachusetts
    09 TRD DoubleC SB
    This is one of my only issues with the truck, but it has to be related to the low first gear in the trans. I drive through an area with two stop signs in a row and the truck frustrates me everytime. I don't come to a complete stop at each one (since I can clearly see each intersection, there is hardly anyone on the road and the signs were placed there to keep drivers from driving to fast on the road), so when I slowly roll through and try to accelerate again, the truck surges as it jumps into second gear. I have an 09' with 6K on it and its done it since new.
  9. Jun 15, 2009 at 8:53 AM
    T-rev
    T-rev Resident Mall Crawler
    Tempe, AZ
    2017 TRD Offroad
    My 08 used to have this issue when I first got it, I have about 17k miles now and it has gone away since now that I think about it.
  10. Jun 15, 2009 at 9:00 AM
    wired_af
    wired_af Well-Known Member
    Alex
    Colorado Springs, CO
    '07 DC TRD Sport S/C
    My '07 does this, but it may not be as pronounced, because I never considered it a problem.
  11. Jun 15, 2009 at 9:11 AM
    Richman21
    Richman21 I think therefore I'm a Democrat
    Jeff
    Albuquerque, NM
    09 DC Sport PreRunner
    Hardwire radar detector. Tube steps.
    My 2009 has the lag issue. I had a 2006 with no transmission lag. I have almost 3,000 miles, the lag seems to be lessening. We'll see.
  12. Jun 15, 2009 at 9:13 AM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
    I didn't realize they changed the transmission between the years. My 07 works great.
  13. Jun 15, 2009 at 9:35 AM
    MassTaco
    MassTaco Well-Known Member
    Massachusetts
    V6 4x4 SR5 DC AT5
    I don't think that it's a "lag" issue. I think the problem is that when the transmission should stay in 2nd gear, it downshifts to 1st. It's an "over-downshifting" problem. When I approach a slow corner (between 10-20 mph) I let off the accelerator and brake as needed, enter the corner then lightly press the accelerator again (maybe 20% throttle). When the accelerator is pressed, the transmission is already in 1st gear, it doesn't kick down to 1st. The transmission then realizes that it's in too low a gear then upshifts to 2nd (and then sometimes 3rd) in rapid sequence.
    This could easily be addressed by a change to the ladder logic in the transmission control module. It's clear that it's being directed to downshift unnecessarily.
  14. Jun 15, 2009 at 9:52 AM
    VancityCK
    VancityCK Well-Known Member
    Vancouver
    09 Magnetic AC TRD Offroad
    I know the problem everyone is referring to, since I have noticed the same thing. I've adjusted my driving habits slightly, and have noticed it less since. Its almost like the truck likes to be driven hard, so I oblige it and give it more gas.:D
    Oh, I've got about 2500 miles on it now, and it has done it since new.
  15. Jun 15, 2009 at 9:53 AM
    sierra141
    sierra141 Well-Known Member
    el paso,texas
    09 prerunner
    3" LIft Toy-Tec
    Maybe because we are used to the older 4 speed automatic transmissions and these newer trucks have 5 speed tranny's one extra gear to cycle. I dont know just a thought..
  16. Jun 15, 2009 at 10:00 AM
    FL4x4Taco
    FL4x4Taco Well-Known Member
    My 2009 Does that same thing!!!!!! If I coast to a slower speed and then get back on the gas.... good god it's down a gear/lag.... reving up.. Not what you'd expect ya know. Me and my wife have noticed it. I just chalked it up as the way the trans is programmed. I can see a trans TSB in the future. And yes I also feel it's a "over down shift" issue.
  17. Jun 15, 2009 at 10:16 AM
    Richman21
    Jeff
    Albuquerque, NM
    My 2009 has the same type of transmission as my 2006 that had no issues.
  18. Jun 15, 2009 at 11:01 AM
    BeachBoy
    BeachBoy Well-Known Member
    VT & QC
    '09 DC LB Sport+Leather
    Icon Extended COs / Camburg UCA / ATX Predator Teflon / Mickey Thompson MTZ / Color-Matched emblems / All-Pro Bumper & skids / Stubbs HD-SKO / Alcans custom leafs / U-Bolt flip / Icon rear resi shocks / Rear Bumper
    my 2009 does it and it's annoying.
    I can't find how to not have it do it, but I found out gunning it is better than trying to get it to go smooth.
  19. Jun 15, 2009 at 11:58 AM
    tussery
    tussery Well-Known Member
    Corpus Christi, Tx
    09 PreRunner SR5
    Magnaflow muffler, TRD CAI.
    I could be wrong but when I have turned off the A-TRAC and Auto LSD my '09 seems to not do this as bad. It kind of seems like the truck is trying to keep you from giving too much gas through the turn.
  20. Jun 15, 2009 at 1:47 PM
    FL4x4Taco
    It's called a bad auto trans program. Or a very aggressive one.
