Transmission leak? Pics*
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JasonJump, Sep 22, 2011.
  1. Sep 22, 2011 at 9:53 AM
    JasonJump
    JasonJump [OP] Well-Known Member
    Yukon Oklahoma
    '05 Tacoma TRD Sport 4X4 D Cab Debadged
    Billy 5100's set at 2.5, iPhone innerface, TRD Sport wheels powdercoated Anthracite grey wrapped in 265/70/17 Duratracs, Custom Sliders
    Hey Guys I took the best pictures I could, looks like my transmission might be leaking.... wondering if this is the case? If so, is the seal a doable replacement myself? Thanks
  2. Sep 22, 2011 at 9:55 AM
    JasonJump
    Yukon Oklahoma
    BTW pictures uploaded sideways, sorry... tilt your head to the left ;)
  3. Sep 22, 2011 at 9:56 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    IMHO, that looks more like the rear main seal of the motor.
    *rotated pics*
  4. Sep 22, 2011 at 10:01 AM
    JasonJump
    Yukon Oklahoma
    Really, I just assumed Tranny because it is right about the Transmission fluid pan.... so main seal of motor? Doesn't sound good as far as replacing?
  5. Sep 22, 2011 at 10:04 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    The rear main seal is actually easier to change than the tranny seal. However both require the tranny to be pulled.
    It's really speculative because both a tranny seal and rear main seal leak would look like that. Now if you can tell whether or not the fluid is transmission or motor oil, then you'd know for sure.
  6. Sep 22, 2011 at 10:07 AM
    JasonJump
    Yukon Oklahoma
    yeah it is tough because it's not leaking bad enough to see if it is red or not. SO either way Tranny has to be pulled, looks like I will have to take it in? Sounds expensive.... good times
  7. Sep 22, 2011 at 10:09 AM
    JasonJump
    Yukon Oklahoma
    Ha guessing there are no DIY threads on Tranny or Engine seal replacement ;)
  8. Sep 22, 2011 at 10:11 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    You could just monitor your engine oil level. I know you can't really do that with the tranny (way to go yota for no f'ening dipstick).
    They should smell different. Have you tried that?
  9. Sep 22, 2011 at 10:18 AM
    Toyota Tech31
    Toyota Tech31 Sometimes when I close my eyes, I can't see.
    Debary, Florida
    '08 SWB Bad ass SPORT
    Air Raid air intake, 40 Series Flowmaster Muffler, Front Turn Signals Now Turn And Park, KENWOOD HEAD UNIT W/ ALL KENWOOD SPEAKER UPGRADES AND 2-10" KENWOOD SUBS BEHIND BACK SEAT, Bilstein 5125'S In Rear W/ 1.5 AAL'S, Bilstein 5100 W/ Eibachs Up Front, LR Upper control arms, NFAB steps, Bruteforce Fab Hybrid front bumper, LP10000 SuperWinch, 2 Rigid Industries SRM-2's, OKLedlightbars 6 CREE LED lights as fogs, AVID RBG, 2 4" red ring HIDs mounted behind the grille.
    I have seen timing cover leaks so bad that when you drive down the road the oil follows the engine to the oil pan and to the area you see in your pics, i could be wrong, but it has fooled some techs in our shop before, also i would look at the valve covers while i am there.
  10. Sep 22, 2011 at 10:29 AM
    JasonJump
    Yukon Oklahoma
    I just recently did 2 drain fill transmission fluids. I change my own oil, I haven;t check the engine oil level lately, I'll check the dipstick. My truck has 120k, and Doubt it had ever had the tranny fluid changed before I did it. Hopefully adding new fluid didn't create the issue. But it could have been like this for a while but never under looking at that area until I did the Drain fill:confused:
  11. Sep 22, 2011 at 10:29 AM
    JasonJump
    Yukon Oklahoma
    I know a little not a ton, but when you say in there.... inside the engine? And check the valve covers in there? Sorry
  12. Sep 22, 2011 at 10:35 AM
    buddywh1
    buddywh1 Well-Known Member
    Philly PA
    07 DC SR5 4x4
    How many miles on it? It looks to be very minor as there's no bright fresh oil streaks or drips along the edge of the pan; mainly a weep that is has wicked out into accumulated road dust.
    Putting it in a shop to pull tranny and put a seal in may cause a lot worse problems than a weeping seal. Especially if it's high miles I'd want to leave it be until it became a genuine leak. Even if low miles, it could go like that 100K miles or more, never weeping enough to show on a dipstick.
    Wipe it off and keep check on it. Consider using a high-mileage engine oil (assuming it's crank seal) with additives that make seals swell a little bit and might even go away.
  13. Sep 22, 2011 at 10:36 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Did you follow the procedure? How recently?
    He means inside the engine bay. Valve covers are on the top of the motor (one pass and one driver side). The timing chain cover is in the front of the motor.
  14. Sep 22, 2011 at 10:40 AM
    JasonJump
    Yukon Oklahoma
    Okay Gotcha
  15. Sep 22, 2011 at 10:44 AM
    JasonJump
    Yukon Oklahoma
    120k, What is a weeping seal? I have though about going to high mileage oil, just hate the thought that I am pushing it under the rug fix with additives, but if it helps it might be what I need to do, good advice
  16. Sep 22, 2011 at 10:47 AM
    JasonJump
    Yukon Oklahoma
    Are you reffering to the DIY Auto tranny drain fill procedure with temp check on here?
  17. Sep 22, 2011 at 10:49 AM
    pinchetaco
    pinchetaco Well-Known Member
    Winston Salem, NC
    06 Taco 6 inch ProComp Lift 35's
    6 inch ProComp Lift, 35x12.50x18 Red Letter Generals, ProComp Wheels, Debadged, Black Headlight mod, Dome Light Mod, Trailer Plug Relocated
    IMO a tiny "leak" like that isn't worth fixing... It will prob cost you more trouble than it's actually worse I would wait until it gets a little worse because that isn't really that bad
  18. Sep 22, 2011 at 10:52 AM
    JasonJump
    Yukon Oklahoma
    I agree, I was asking to see if there was an easy preventative step I could do to keep it from getting worse, or easy fix.
  19. Sep 22, 2011 at 11:05 AM
    BlueT
    BlueT Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    You know you can drive with leaking rear main seal for like forever :D Just keep oil level topped and you are golden. Rear main seal is fun job and its even funnier when you indeed find out it was your valve cover leaking :eek: Still 120k Miles sounds about right for rubber seal.
  20. Sep 22, 2011 at 11:22 AM
    JasonJump
    Yukon Oklahoma
    Ha thanks, 120k sounds about right for what seal? all of them probably :rolleyes:
