Transmission Leak Question
Discussion in 'Technical Chat' started by goufcustom, Dec 15, 2012.
  1. Dec 15, 2012 at 9:18 AM
    goufcustom
    goufcustom [OP] 7.62x63mm
    MD
    2006 4x4 TRD Off Road DC SR5
    Bed Topper, Diff Breather, aFe Cold Air Intake, Satoshi Grill, Moved Horns, Oil Catch Can, Tailgate Lock, Husky Mud Flaps, H4 65/70W Bulbs, Lower Grill Mesh, TRD Skid Plate, LEDs in the bed, LEDs behind the grill for accent lighting, Parking lights as turn signals, LED turn signals and reverse lights, 5100s up front, eibachs up front, SS extended brake lines all around, 1.5" AAL in the rear, Relentless Fab U-Bolt Flip Kit, ICON Progressive AAL, TRD Wheel Center Caps, HomeLink, Heated Driver Seat, Hella 500 FF Driving Lights, BAMF Diff Skid, BAMF LCA Skids, BAMF Rock Sliders w/ KickOut.
    I was greasing my drive shaft and noticed this while I was under there...
    I assume I need to pull the pan and replace the gasket, change the filter while I am there and replace the ATF fluid too. Thoughts?
    I have noticed over the last month or so it shifts a little harder, I typically get a thud when it is warming up and I am driving out of my neighborhood.
    Parts for this look cheap, and seems easy enough, imagine something will go wrong, but worth a shot.
  2. Dec 23, 2012 at 12:53 PM
    06SR5canada
    06SR5canada Well-Known Member
    Saskatchewan
    06 dblcab SR5
    2ndary air filter removed, flowmaster 40
    I'd just try crank the bolts a little
  3. Dec 23, 2012 at 2:06 PM
    goufcustom
    MD
    I checked the torque on all of them and they were at ~35 in-lbs or less, so I took them all to 65 in-lbs and cleaned it up. I have been checking it every other day and there are no leaks.
    I would recommend everyone check the torque on their transmission pan, it is very easy, and worth the time.
