transmission leak??
Discussion in '1st Gen. Tacomas (1995-2004)' started by heshdog, Dec 4, 2010.
  1. Dec 4, 2010 at 9:56 AM
    heshdog
    heshdog [OP] skating, music
    VA
    01 Tacoma Pre-runner TRD 2x4
    had my transmission flushed and refilled last week...now i'm seeing spots on the pavement..I took some pics to post...It's not leaking from up top and running down...It seems to be coming out of the box?? when it was first done i saw some the next day but figured it was just from having it done..My transmission fluid level seems fine nothing low or anything..I"m just worried that it's a slow leak or something
    1. how and why does this happen?
    2. how do i fix this
    3. should i take it back to the shop..I went cheap and against my better judgment and had it done at....jifffypoop..The closest mechanic I trust is like a 30min drive..It's hard getting work far away with my kid with me..
    pics>
  2. Dec 4, 2010 at 9:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Take it back, and make them fix it. It looks to be leaking from the dip stick tube...
  3. Dec 4, 2010 at 10:16 AM
    heshdog
    VA
    i thought so too..but it has no fluid up in the tube?? it's strange.seems to be leaking from the box?
  4. Dec 4, 2010 at 10:20 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well....the dipstick tube is 2 piece...with an o-ring where it disconnects in the middle. they may have nicked the o-ring while putting it back. it'll look like its coming from the pan......but it'll mostly come from where the o-ring is.
  5. Dec 4, 2010 at 10:26 AM
    heshdog
    VA
    ok..I"ll check again on the dipstick tube....
    If it is the pan..how can I fix it??..
    I really don't trust the knuckleheads to fix it..I already had to take it back because they didn't fill up coolant reservoir...
  6. Dec 4, 2010 at 10:30 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    do this.......spray the area with brake cleaner...all the way up the tube. then....put a piece of masking tape on down the tube.....past the split in the tube. then drive it....if you see tranny fluid getting on the tape...you know its coming from the o-ring area. if its the pan....you'll be able to tell. im betting solidly on it being the o-ring tho.
  7. Dec 4, 2010 at 10:35 AM
    heshdog
    VA
    thanks man..I appreciate the quick resposne..will do it today and follow up on this thread..
  8. Dec 4, 2010 at 10:36 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    cool...good luck. let us know how it turns out.
  9. Dec 4, 2010 at 12:20 PM
    heshdog
    VA
    ok..depending on what the problem is..is it an easy fix whether it's the box or tube?
  10. Dec 4, 2010 at 5:24 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if its mid tube.....new o-ring will do it(grease the o ring a bit before reconnecting tube)...if its pan....if sanding and some jb weld dont fix it...you'll need another pan.
  11. Dec 5, 2010 at 7:52 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    I had mine flushed at the dealer and I was concerned about leaks after the flush, but when I got to looking at the truck I figured they did not remove the pan just disconnected the ATF lines at the radiator cooler, to flush it, granted they did not wash out the screen filter but now thinking back on it I am glad they did it the way they did.
