Transmission leaking fluid!!! FML
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Sack17, May 5, 2010.
  1. May 5, 2010 at 9:20 PM
    Sack17
    Sack17 [OP] Well-Known Member
    Andrew
    Sanibel, FL
    05 Tacoma DBL Cab TRD Sport 4x4
    Bed lights Blacked out sport wheels blacked out emblems BHLM Spidertraxx 1.5" wheel spacers factory roof rack custom yakima wind fairing w/ PIAA off road lights up top snowboard/ski rack surf board pads fog light mod custom interior cup holder l.e.d. lights Bestop topper custom L.E.D. rear facing lights Maglite mod (2 front seats) 3.25" in the front 2.5" in the rear 6 Hella 500ff's (w/ Silverstar's) Silverstar Ultra's in headlights Silverstar Ultra in fogs (retro-fitted 65w 9005's) Hi-Lift (mounted on side of bestop) Shovel (mounted on side of bestop) custom 1.5" body lift
    So went mudding the other night and next morning went to the gas station and noticed I was leaking transmission fluid on my 2006 DBL Cab TRD Sport. So me and my neighbor pulled the tranny and replaced the front pump seal (because it was leaking from the front of the tranny vent, right above the oil pan) and just went and test drove it and it's still leaking from the same effin spot. He and I thought that since it wasn't leaking from the rear that that's the only thing that it might be. Anyone have any suggestions????
  2. May 5, 2010 at 9:26 PM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    Drain plug washer? if its the same as the oil washers they are supposedly crap
  3. May 5, 2010 at 9:36 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    I'm not sure but dont you have to take it to a stealership to make sure you have the right amount of tranny fluid in it?
  4. May 5, 2010 at 9:38 PM
    Sack17
    Andrew
    Sanibel, FL
    Nah it's leaking from what appears to be a vent with a black plastic piece, the drain plug is dry as a bone. It only leaks when the truck is running so thats why we thought it was the front pump seal. I am clueless but I do know that was a bitch to get apart and it still leaks, fuuuuck.
  5. May 5, 2010 at 9:39 PM
    Sack17
    Andrew
    Sanibel, FL
    True WW, but the kicker is, my grandmother's neighbor is a mechanic at the local Toyota stealership and that's who helped me take it out lol
  6. May 5, 2010 at 9:40 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Ohhhh!!!!! Well hell, he should know whats up then!!:eek:
  7. May 5, 2010 at 9:41 PM
    Sack17
    Andrew
    Sanibel, FL
    Haha I know, one would think. But now he's stumped too.
  8. May 5, 2010 at 9:42 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Okay chris4x4....this is the time where you can show up a Toyota mechanic!!!:eek::D
  9. May 5, 2010 at 9:45 PM
    Sack17
    Andrew
    Sanibel, FL
    Hahaha I was hoping he would chime inn here lol
  10. May 5, 2010 at 9:47 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    He will. Just give him some time.:pccoffee:
  11. May 6, 2010 at 6:34 AM
    jackwithcorona
    jackwithcorona Well-Known Member
    Eastern Mass
    13 DCSB SR5 4x4
    bestop supertop, rubber bed mat, weathertech floor mats
    lol
  12. May 6, 2010 at 7:17 AM
    dimitrik
    dimitrik Well-Known Member
    Dimitri
    Quebec
    09 Access Cab TRD-Offroad
    AllPro Skidplate
    Get a manual
  13. May 6, 2010 at 10:36 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    Very constructive post.
  14. May 6, 2010 at 10:40 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
    265/75R16 Falken Wildpeak AT3 LED Bulbs Access Lorado
    Picture? It would help..
  15. May 8, 2010 at 3:53 PM
    Sack17
    Andrew
    Sanibel, FL
    Of what, the pool of fluid on the ground lol
  16. May 8, 2010 at 5:44 PM
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    No, a picture showing where the fluid is leaking out
  17. May 9, 2010 at 9:15 AM
    dually
    dually Low and slow
    Theres only a few places it could leak.. Unless your trans is cracked.
