Transmission Life
Discussion in '4 Cylinder' started by CLMVVC, Oct 13, 2014.
  1. Oct 13, 2014 at 5:35 PM
    CLMVVC
    CLMVVC [OP] Member
    98 Tacoma 4cyl.
    grille guard, off-road tires
    How long can I expect the transmission on my 98 2.7L to last? it has 132k miles on it now.
  2. Oct 13, 2014 at 5:39 PM
    zbaldo
    zbaldo Well-Known Member
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Stock as Stock can be with duratracs and a roof rack
    Long time is probably your only answer if not abused. 4wd?
  3. Oct 13, 2014 at 5:40 PM
    zbaldo
    Ozzy
    Torrance, Ca
    99 4Runner SR5 4X4
    Really though everybody usually gets 200k before problems become statistically significant.
  4. Oct 15, 2014 at 3:30 PM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    I hope your W59 gives you many more miles of trouble-free service. Most do.
    I have to overhaul my R155F at 146k. I can't rule out abuse by the first owner. I'm guessing he towed in 5th gear judging by the rather expensive dealer-installed tow package most four cylinders don't have.
  5. Oct 15, 2014 at 3:32 PM
    thewarriordinghy
    thewarriordinghy General Lee's Titan
    Ben
    Georgia
    2017 Nissan Titan 4x4
    Temporarily Stock
    just flush it and keep up with the maintenance and it'll go 132k more!
  6. Oct 16, 2014 at 6:01 AM
    CLMVVC
    CLMVVC [OP] Member
    98 Tacoma 4cyl.
    Yeah, mine is 4wd.
  7. Oct 16, 2014 at 6:02 AM
    CLMVVC
    CLMVVC [OP] Member
    98 Tacoma 4cyl.
    And thanks everybody!
  8. Oct 22, 2014 at 6:52 PM
    JEA86
    JEA86 Well-Known Member
    Jeremy
    WV
    2016 TRD Off-Road
    Yeah it's hard to wear something out that lives its whole life being lubricated, keep the fluids changed and don't abuse it, will last forever
  9. Oct 24, 2014 at 7:11 AM
    Fordless
    Fordless Well-Known Member
    Jack
    Central Alabama
    2015 Tundra DC SR5+
    I disagree with this statement simply because I've owned a Chevrolet transmission and a 6.0L Powerstroke Diesel. No amount of lubrication or pampering can supplant Bad engineering or substandard parts suppliers.
    Luckily Toyota rarely releases Beta testers to the public.
  10. Oct 24, 2014 at 7:22 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    285,000 on my old one had to replace the clutch at 206,000 towed a small camper all over the country.
  11. Oct 24, 2014 at 10:58 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    People are recommending a transmission flush for your stick shift, so I'd take some of these replies with a grain of salt.
    If someone knows how to drive a stick shift/ knows how a synchronizer works, checks the gear oil level once a year (transmission, transfer case and axles), and changes the transmission gear oil about every 50,000 miles, I think it should last 200k or more (barring any design flaws or abuse by previous owners).
    I've had 5 vehicles with stick shifts and only had a problem with one, 1965 Mustang 6-cylinder 3-speed, it was just a weak design transmission. All the others were flawless over many many miles.
    I've seen someone shove their stick shift into 2nd gear at 60+mph without a throttle blip... that kind of stuff makes me cringe. Just because something is tough doesn't mean it should be abused.
  12. Oct 24, 2014 at 2:47 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Change the fluid and it will go indefinitely.
  13. Oct 24, 2014 at 4:14 PM
    iroh
    michigander
    tonneau
    The inside of my case showed that the gear lube had been really low and really hot at some point before I bought it. It cooked to the case at a level at least 2" below the fill plug. That's likely why I had to clean out the part of the 5th gear bearing that turned into gray goo out of the gear.
    Yep, good oil of proper level is everything. I'll probably go with a 30k interval on this now after the rebuild.
  14. Oct 25, 2014 at 4:52 AM
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    Early iron case 5spds. had wicked issues with bearings no exceptions. The early aluminum case 5 spds. had some problems with 5th gear but most any thing beyond that has been pretty flawless they will out last the truck. Toyota recommends 30K service many never get serviced and still last 200+K
