Transmission life
Discussion in '1st Gen. Tacomas (1995-2004)' started by HarlessR, Feb 23, 2017.
  1. Feb 23, 2017 at 2:47 PM
    HarlessR
    HarlessR [OP] Member
    1997 Tacoma
    I recently got a 97 tacoma with 300k on the clock. Just wondering the life expectancy of the auto transmission? It has a 2.7 engine that I'm replacing. I really don't know much about the history of the truck. Thanks.
  2. Feb 23, 2017 at 4:09 PM
    eon_blue
    Azusa, CA
    If it was taken care of properly (fluid changed out in regular intervals) and not abused or used in heavy towing, then it should last you awhile longer. 300k is a lot of miles though
  3. Feb 23, 2017 at 4:11 PM
    outlawtacoma
    outlawtacoma Well-Known Member
    W. TN
    2018 T4RTRDOR
  4. Feb 23, 2017 at 4:47 PM
    99SuperTaco4x4
    99SuperTaco4x4 Well-Known Member
    1999 3.4L V6 Tacoma, 4x4, TRD Supercharger
    I think its anyone's guess without the maintenance history.
  5. Feb 23, 2017 at 6:54 PM
    HarlessR
    1997 Tacoma
    I had a guy tell me not to change the fluid if it hasn't been changed its regular intervals. He said it would give me trouble of I do change it. Has anyone else heard this? Thanks for the input.
  6. Feb 23, 2017 at 7:42 PM
    gearcruncher
    Canadain bumper technician
  7. Feb 23, 2017 at 7:50 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    Yes, dont do a flush. Instead do multiple pan drain and fills with around 1-2 weeks in between each drain. It will slowly get alot of the old fluid out and get some new fluid in there.
  8. Feb 23, 2017 at 7:57 PM
    mbmack1
    mbmack1 That F'n guy
    matt
    az
    SAVAGE silver '06
    I had a 1996 3.4L v6 before I traded it for my current '06. 301,000 mi on it when I traded it in. Original tranny was still going strong. I realize that this is pretty much where you're at right now so this may not help much but I figured I'd throw it out there.
  9. Feb 24, 2017 at 7:06 AM
    HarlessR
    1997 Tacoma
  10. Feb 24, 2017 at 7:13 AM
    HarlessR
    1997 Tacoma
    Would an automatic trans from a 2002 prerunner two wheel drive work in my 97 4x4 tacoma? Also would the engine (2.7) out of the same 02 prerunner switch right over without any modifications? Would I need the ECM from the 02? My 97 does have the coil pack also. Thanks again for the help.
  11. Feb 24, 2017 at 8:05 AM
    pray4surf
    pray4surf Well-Known Member
    Rick
    Oceanside, CA
    98 PreRunner conv to 4x4
    F&R suspension, OBA, Custom bed rack, RTT, rear frame plates, 4x4 conversion from prerunner, many other
    The PreRunners had a transmission coded A340E, the 4x4's an A340F. Essentially the same trans - different tailshafts. Prerunner trans goes straight to the driveshaft, the 4x4's mate up to the transfer case. You can swap tailshafts...
  12. Feb 24, 2017 at 8:29 AM
    HarlessR
    1997 Tacoma
    That's what I was curious t to know, if the tail shaft was bolted on. Thanks.
    pray4surf[QUOTED] likes this.
  13. Feb 24, 2017 at 8:42 AM
    pray4surf
    Rick
    Oceanside, CA
    I don't have links, but the process has been discussed in the forums before
  14. Feb 24, 2017 at 8:51 AM
    weenerdog
    weenerdog Member
    2023 Barcelona OffRoad DCLB
    I assume a filter change is recommended? Would this be after a few drains?
  15. Feb 24, 2017 at 10:18 AM
    pray4surf
    Rick
    Oceanside, CA
    There is no external filter. You'd have to drop the transmission pan to gain access. The filter is nothing more than a metal screen. While you have the pan off, you can clean the magnets that collect the metal shavings... You will get more fluid out dropping the pan than you would with a simple drain.
  16. Feb 24, 2017 at 10:32 AM
    gearcruncher
    Along with removing the pan and cleaning the mesh style screen , you could always disconnect the lower transmission cooling line and drain the converter
    pray4surf likes this.
  17. Feb 24, 2017 at 10:39 AM
    weenerdog
    weenerdog Member
    Great info, thanks!
  18. Feb 24, 2017 at 10:43 AM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    I tend to fallow the manufacturer's suggestions. My 2009 has 71,000 and nothing come up in the normal requirements as far as maintenance for transmission. It it's true
    now a day I am into my new ride I just acquired a wile back, but I do not want to miss anything as far as maintenance on my old trusted truck. I think nothing is required to do till 100,000. But I may be wrong, please correct me otherwise.
  19. Feb 24, 2017 at 11:04 AM
    gearcruncher
  20. Feb 24, 2017 at 11:07 AM
    gearcruncher
    https://www.tacomaworld.com/threads/transmission-swap-write-up-s.384303/
    https://www.tacomaworld.com/threads/transfer-case-transfer-cases-in-first-and-2nd-gen-trucks.345652/
