Transmission life
Discussion in '1st Gen. Tacomas (1995-2004)' started by HarlessR, Feb 23, 2017.
  1. Feb 24, 2017 at 11:10 AM
    HarlessR
    HarlessR [OP] Member
    1997 Tacoma
    Thanks for all the info on the transmission. Should I post my question about the 2.7 swap in a different post?
  2. Feb 24, 2017 at 11:13 AM
    gearcruncher
    Canadain bumper technician
    You would most likely get better attention and more accurate information if you started a new thread
  3. Feb 24, 2017 at 12:56 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
  4. Feb 24, 2017 at 8:21 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    The filter is just a metel screen, not really needed to change
  5. Feb 25, 2017 at 6:28 PM
    OleRomer
    OleRomer Professional Vagabond
    Brandon
    Utah/Wyoming
    04 Tacoma –- Ole Rømer
    ICON 2.5 Ext Travel C/O, Camburg UCAs, AllPro Expo Leaf Springs, ICON 2.0 RR Shocks, ARB/RAT/BAMF/CaptureColorado Armor, Dual Optimas Red/Yellow, 133w Solar System, Custom Bed Build, etc., etc.
    These auto transmissions will go for a LONG time if maintained normally.
    The only addition is installing an auxiliary tranny cooler. Over heating is a sure way to kill one. The Tru-Cool 4544 has a bypass feature that keeps it from over cooling the fluid.
    That's where my money was spent.
  6. Feb 26, 2017 at 7:10 AM
    Glamisman
    Glamisman Well-Known Member
    ATF has a lot of cleaning agents in it. If your trans fluid has lots of miles on it there is a possibility that a "flush" could loosen all of the particulates that have clung to the various places and cause the valves and selinoids to stick... a gradual fluid change is what I reccommend and like in a prior post taking the trans out put line off the radiator and letting the trans pump it out a quart or 2 at a time is relativly easy way to do it. If you take the wrong line off and let the trans pull air there is a small chance that you could do damage to the oil pump in the trans by running it dry.
  7. Feb 26, 2017 at 6:27 PM
    weenerdog
    weenerdog Member
    2023 Barcelona OffRoad DCLB
    So, the owner's manual says "Dexron III", so I assume it's ok with that in lieu of the actual Toyota fluid...
  8. Feb 27, 2017 at 5:03 AM
    HarlessR
    1997 Tacoma
    Do you need to plug off the return line so it doesn't suck in air?
  9. Feb 27, 2017 at 5:38 AM
    1997tacomav6
    Denver
    Put in a 5 speed, will last forever, coming up on 520,000,
  10. Apr 1, 2017 at 3:06 PM
    Glamisman
    just dont let it run dry... a 3 second run and look and see how much comes out, top off, repeat. If you want you could put the return hose in a large container with trans fluid and monitor it but that is just one more thing to do. The trans pump pulls from the trans pan fluid and it holds quite a bit.
  11. Apr 1, 2017 at 3:37 PM
    HarlessR
    1997 Tacoma
    Since I'm having to put an engine in this truck, can I take the torque converter off and drain it then and just drain the pan also? Can I flush the converter with anything also while is off? Something that would clean it out and the pan also when I take it off? Thanks.
  12. Apr 1, 2017 at 3:52 PM
    Glamisman
    yes you can. if you have not done anything like this before use a little caution on reinstallation of the torque convertor. I have no way of knowing your mechanical abilities or knowledge... no insult intended. I would put a straight edge, a piece of wood, something you can measure from to see just how far the torque convertor sits on the front of the trans this is important because on some models the torque convertor can be installed but not all the way and the pump wont engage the convertor... the eingine will be a real pain to try to install and if you do manage to get it seated you might break the pump internally or not engage it at all which will destroy the trans post haste... I forget how many "notches" you feel when installing the torque convertor 2 or 3, it has been a while, I just measure to be sure.
    You are gonna have your hands full on inital start up... starting it and running her for 4 or 5 seconds, shutting her down then adding trans fluid, repeat. You dont want to run the trans dry.
  13. Apr 1, 2017 at 7:13 PM
    HarlessR
    1997 Tacoma
    I've had a few converters out but its been years, I appreciate your advice on measuring first. I haven't drained them before though, can I pour fluid back into it before installing? Can I clean it out(flush it) with maybe some gas or kerosene to clean?
    Thanks for your input.
  14. Apr 1, 2017 at 10:29 PM
    Glamisman
    no on the gas or kerosene but yes to dumping the convertor and pouring in new fluid from the bottle right into the convertor. the issue is how much to pour in and not make a mess when you rotate it to install if you over fill.
