Transmission line leaking near exhaust
Discussion in '1st Gen. Tacomas (1995-2004)' started by bhockenstein, Sep 15, 2017.
  1. Sep 15, 2017 at 10:17 AM
    bhockenstein
    bhockenstein [OP] Member
    1998 Tacoma, automatic
    I have a pretty bad transmission fluid leak on a line running down the right (passenger) side of the tranny right near the exhaust.... a friend of mine took a look under and said it was the transmission fluid return line and that it should be pretty easy to swap out but I can't seem to find any info online at all as far as parts or replacing/fixing...
    Anyone familiar with what I am talking about?
  2. Sep 15, 2017 at 10:43 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Which part is leaking? There is a 90 degree (roughly) union that threads into the side of the transmission and connects to the inverted flare hard line. The part that is threaded into the transmission uses an o-ring to seal. The part that threads onto the hard line seals without anything extra since it is a flare fitting.
    O-ring part number 90301-11006
    If you need to replace the union, the one labeled as outlet is actually the inlet in toyota's system. I ordered the inlet part number, thinking I would get the return line union, but I actually got the outlet line union.
  3. Sep 15, 2017 at 12:36 PM
    bhockenstein
    it seems to be leaking from the end of the 90-degree union that threads onto the hard line.
    Does that means I need to replace the 90-degree union? do you know the part number or name? or is it just called the "90-degree transmission fluid return line union"?
  4. Sep 15, 2017 at 12:38 PM
    bhockenstein
  5. Sep 15, 2017 at 1:16 PM
    nzbrock
    Noah
    San Marcos, TX
    This is how toyota labels them (although your link is opposite)
    Inlet – 90407-16012
    Outlet - 90407-16009
    The front union (the longer one) is the return line and is part number 90407-16009
    If it is leaking at the hard line to union connection, you might be able to tighten it. If you do this I suggest using a brake line wrench.
    The o-ring goes on the transmission side.
    There is no telling if the hard line or the union is bad until you remove it.
  6. Sep 15, 2017 at 1:27 PM
    bhockenstein
    Great. Thanks so much for the help!
  7. Sep 15, 2017 at 1:58 PM
    gearcruncher
    Canadain bumper technician
  8. Sep 15, 2017 at 2:26 PM
    bhockenstein
