Transmission Line
Discussion in 'Technical Chat' started by avidnyhunter83, Oct 18, 2014.
  1. Oct 18, 2014 at 9:23 AM
    avidnyhunter83
    avidnyhunter83 [OP] Member
    Shawn
    Finger Lakes, NY
    06 Tacoma TRD 4WD.
    I have a 2006 Tacoma V6 4X4 with the off road package. Last summer I had to replace the power steering line because part of the line had corroded. I was replacing the serpentine belt today and noticed that another line was corroded. I traced the line back to the side of the transmission pan. There are two lines going into the pan, and the one on the left is the one that is leaking. The part that is corroded is up near the front of the engine.
    Anyone know what the name of this line is so I can get the right part ordered? Where is the best place to order from? Any help is appreciated!
  2. Oct 18, 2014 at 10:59 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I don't have a 2nd gen, but it sounds like those are the tranny cooler lines. If so, the other ends should be attached to the radiator.
  3. Oct 18, 2014 at 5:22 PM
    avidnyhunter83
    Shawn
    Finger Lakes, NY
    06 Tacoma TRD 4WD.
    Does anyone know if the transmission cooler lines are low pressure lines? If so, I think I can replace it with hose instead of the metal OE line that corroded.
  4. Oct 18, 2014 at 5:36 PM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    The hard lines lead in to soft lines to go in to the trans cooler. What you are looking for is the No. 1 oil cooler outlet and inlet tube. Looks like the outlet is the rear most fitting, and the inlet is the forward most fitting.
  5. Oct 18, 2014 at 5:44 PM
    MPW
    MPW Member
    Mark
    Virginia
    Not high pressure as in power steering pump pressure, which can be well over 1000 PSI. Transmission line pressure can run close to 100 PSI but the cooler circuit is probably a bit lower.
  6. Oct 18, 2014 at 10:52 PM
    tan4x4
    Rick
    Folsom, CA
    Don't use any old hose. The materials used in various hoses are designed to resist getting eaten up the particular caustic fluid running thru it (gas, ATF, PS fluid, brake fluid, etc).
    You can get away with using any old hose for vacuum lines and maybe coolant.
  7. Oct 19, 2014 at 6:15 PM
    avidnyhunter83
    Shawn
    Finger Lakes, NY
    06 Tacoma TRD 4WD.
    The problem is I'm having trouble finding replacement line. It seems to be pretty easy to bend the tube with a tube bender you can buy at Home Depot, but where do I buy the line? I'm going to check Autozone tomorrow.
  8. Oct 19, 2014 at 6:22 PM
    gearcruncher
    Canadain bumper technician
    genghis71 likes this.
