Transmission logic update is on the way
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Howanic, May 3, 2016.
  1. May 4, 2016 at 9:46 AM
    eseckinger
    eseckinger Well-Known Member
    Eric
    2018 TRD Sport
    Yes, it also hurt fuel economy. More than likely this new flash we get will do the same. Don't think there is any alternative at this point.
  2. May 4, 2016 at 9:50 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    I'd gladly take more low end torque and less gear hunting for a 1 to 2 mpg decrease avg in Fuel Economy. I have serious doubts it would even be that much of an impact.
    Kilokato, IamEric, hr206 and 4 others like this.
  3. May 4, 2016 at 12:15 PM
    stevebaz
    stevebaz Well-Known Member
    2016 access cab, TRD offroad 4x4, Quicksand
    I just did my customer Quality Control survey. It was in 2 parts. The first part was for engineering and the second part was for their Quality control Department. The first part touched on most of the issues here and the second part included all the same questions as the first part and went into more detail as to the quality of the whole truck. It didn't touch on dealer issues. I raped them a good one on the automatic transmission and idle surge issues especially when backing up. I doubt it will go anywhere but I am at least a bean in the count. Most of the other issues and complaints with the 2016 I don't have.
    For my sanity I drive my V6 Offroad 2016 in ect mode these days. Equal parts stop and go freeway and stop and go streets. I get 17-19 MPG in ect and the rare long freeway run shifter in drive I have gotten 20.5 But I have less than 2000 miles on the truck. Other than rock sliders and some stickers, the truck is the same as it left the factory. I use California blend Chevron regular gas. Street only mileage takes a severe hit in mileage numbers. I do allot of less than 5 mile jaunts.
  4. May 4, 2016 at 12:33 PM
    HerculesRockefeller
    HerculesRockefeller Well-Known Member
    2018 Cement Tundra Double Cab TRD Off Road
    I'm not sure exactly what the issues are that people are having with shifting on cruise control. Mine seems to work fine, if I'm on the highway and it's on cruise control, usually it's in 6th gear and purring nicely. If I head up hill, it will drop to 5th to keep the speed steady. I would venture to say the cruise control on my 2010 4Runner was a lot more unusual, it had a tendency to shift gears all the time and it wasn't uncommon for the thing to send me screaming past the set speed when going up a hill. It was ok on a flat road but anywhere else and it was all over the place.
  5. May 4, 2016 at 12:40 PM
    thors.hammer
    thors.hammer Well-Known Member
    Be careful? All they could do is improve it.
    Oh, and regarding your cruise control issues, what were the problems? My 2013 works very nicely.
  6. May 4, 2016 at 12:43 PM
    darncart
    darncart Well-Known Member
    The EPA stuff is BS. The way it is now, many of us are flooring it to get the torque we need, which is much worse on fuel usage. If the EPA doesn't cave, people are not going to even come close to the EPA numbers they are estimating for this vehicle wihtout driving extremely feather-footed.
    After my first tank got about 15 MPG (I'm assuming they filled it with 87 or 89). My second tank I used 92 octane and got about 18. Several drives I've been able to achieve over 20 MPG average. But that is with extreme feather-foot and shifting to nuetral on any semblance of a downhill slope to coast it up to better numbers. If I were to drive this thing normally, or in the spirited way it is supposedly supposed to be driven. I would be getting about 16 MPGs with 92 octane. That may get better after my first 1 - 2k miles. Have to see.
    smitty99 likes this.
  7. May 4, 2016 at 1:41 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    It worked, I just didn't like the way it worked. Speed would drop below the set speed by 2-3mph then drop a gear and race back up to 2-3 over. Several trips back and forth between Seattle between Redding and the Bay Area I used it occasionally and each time I hit a little head wind it would do that and I didn't like the constant dropping a gear to play catch up. I just choose not to use it anymore. I like having my foot on the pedal a lot more than using CC.
    CusterFan likes this.
  8. May 4, 2016 at 2:10 PM
    viking15
    viking15 Well-Known Member
    Joe
    Cant you just unplug the battery say overnight and accomplish the same thing
    The Dude 80 likes this.
  9. May 4, 2016 at 2:11 PM
    Howanic
    Howanic [OP] Well-Known Member
    Utah
    2016 TRD OR Double Cab 4X4 A/T Inferno
    When cruise is set to about 70-75 and tries to stay at the set speed during wind or any incline it will sometimes drop to 4th and stay there until you manually turn cruise off. The Toyota rep told me it is another logic issue that will be fixed in the update.
    Kilokato likes this.
  10. May 4, 2016 at 2:12 PM
    Howanic
    Utah
    Unplugging the battery for at least 30 mins erases the short term memory. Not the long term. You have to flash it to get it back to factory memory.
  11. May 4, 2016 at 3:11 PM
    swimmer
    swimmer Well-Known Member
    Tucson
    2016 TRDORAC4WD
    As has been said. Drops from 6th gear to a lower gear to ascend a hill but once the hills is crested and you resume flat terrain the transmission is reluctant to assume the high gear that was previously acceptable. You need to tap the CC down, tap it up or, turn it off in order for the truck to pick the higher gear. I have no other issue with the transmission or any other part of the truck.
    pete37, Howanic[OP] and 3dBdown like this.
  12. May 4, 2016 at 3:30 PM
    TacoJonn
    TacoJonn Well-Known Member
    Jon
    Laramie, Wyoming
    '13 DCLB Sport 4x4, '78 FJ40
    Don't think they can significantly change the tune of the tranny. RPMs are dead until hit 3,000 or more RPMs. Not the same on the manual. You would have to totally re-gear the auto to get it drive good again and they can't do that with the EPA. The auto would need totally redone to make it feel anything like the 4.0 or the the 3.6 in the Colorado. If the 3.5 auto drove like the Colorado I would own one by now.
  13. May 4, 2016 at 3:31 PM
    smitty99
    Scottsdale
    I think you just have low standards
  14. May 4, 2016 at 3:44 PM
    swimmer
    Tucson
    2016 TRDORAC4WD
    That's interesting. Wonder of there is something different with the Canadian software.
  15. May 4, 2016 at 3:55 PM
    #35
    FritoBandito
    FritoBandito Well-Known Member
    Texas
    2016 Limited 4X4 DCSB
    It's odd that it takes so long to fix the issues. I traded in a 2014 Jeep Grand Cherokee that also had shifting issues from the start and Jeep released a fix in a couple of months. I didn't have to print anything out or argue.. it was simply fixed when I brought it in. The shift points are wonky on this truck and Toyota knows it.. so fix it. The process doesn't have to be complicated and make the customers frustrated.
    Kilokato and smitty99 like this.
  16. May 4, 2016 at 4:26 PM
    #36
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    I like my cruise control when I have a tailwind or on a day the wind is not blowing here on the prairie.
  17. May 4, 2016 at 4:47 PM
    #37
    FritoBandito
    Texas
    I think you misunderstood my post. I know software can be complicated.. I've been a professional software developer for the past 20 years and the software I've developed is used in highly complex financial applications where hundreds of billions of dollars are managed. That said.. what shouldn't be complicated is once there is a TSB.. getting the dealer to apply it to your vehicle. Others were mentioning printing it off, then arguing with the dealer, etc.. that's all. Getting the dealer to apply a TSB shouldn't be a difficult process.
  18. May 4, 2016 at 5:50 PM
    #38
    HerculesRockefeller
    Don't think so, I live in America and my experience is the same as his.
  19. May 4, 2016 at 6:42 PM
    #39
    mustangwilly
    mustangwilly Well-Known Member
    2017 DCSB OR Quicksand MT
    Go drive 75mph and over and report back. You will be in 4th and 5th gear most of the time unless you have a hell of a tail wind.
    nlg4021 likes this.
  20. May 4, 2016 at 6:53 PM
    #40
    HerculesRockefeller
    Sorry, this just isn't happening with my truck.
