Transmission Maintenance for 2nd Gen Tacomas : when is the right time?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Ajay Naik, Feb 25, 2017.
  1. Feb 25, 2017 at 2:26 PM
    Ajay Naik
    Ajay Naik [OP] Member
    Ajay
    Mountain View
    2014 Double Cab 4x4 TRD Sport
    hey guys,
    i have a 2014 TRD Sport v6 4x4
    when is the right time to get the transmission maintenance done
    i dont trust these guys at the dealerships and two different dealerships gave me two different answers
    also, what do i need to get done as part of the transmission maintenance (transmission oil change, etc...?)
    would be very helpful to get your thoughts and advice here
    thank you so much
    your fellow tacoma lover
  2. Feb 25, 2017 at 2:33 PM
    ZachPrerunner
    ZachPrerunner Sometimes she goes, sometimes it doesn’t
    Southeast TN
    ‘07 TRD Offroad / ‘19 TRD Offroad 4x4
    I did the DIY drain and refill around 120k. Toyota basically states that it should be serviced at 100k. There's a bunch of speculation about the WS fluid, but I wouldn't service it until 60k at the very minimum. You can find the write up here: https://www.tacomaworld.com/threads/how-to-drain-refill-automatic-transmission.63851/
    If you're wanting to do a flush, you'd have to check up with a dealership that has the machine. I know some individuals on here have found that many of the dealerships just perform the drain and refill, but list it as an "ATF Flush". Hope this helps!
  3. Feb 25, 2017 at 2:38 PM
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Devil Horns by Andres, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers, Pop and Lock tailgate theft deterrent mod 2.0, Plasti-dip rear bumper. Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Mostly depends on how you use it. Sooner is better.
  4. Feb 25, 2017 at 3:16 PM
    ZachPrerunner
    Southeast TN
    I have to disagree. Sooner isn't always better. It's like saying you should change your oil every 1k miles because it is "better" for your engine. Even though it doesn't hurt anything, it isn't practical and is very wasteful. That's why I would recommend the service until 60k. It utilizes the fluid to its capacity. Unless someone tows a lot and doesn't have a transmission cooler (which is dumb in the first place), I would say 80k miles is a more appropriate time to service. Some on here haven't even changed their fluid until 200k+ and they're still functioning just fine.
  5. Feb 25, 2017 at 3:17 PM
    gearcruncher
    Canadain bumper technician
    Use to be 100k but Toyota dropped it down to 60 k due to warranty issues
    I am going with the sooner the better approach as well . An all aluminum valve body in the A750 series transmission . Keep it clean .Fresh fluid Keeps that sandpaper away from the spool valves .
    https://www.tacomaworld.com/threads...th-pics-for-second-gen-4-liter-trucks.289913/
    Remove your transmission pan before you flush your transmission . Ask me why ??????. Read below
    Hook78 just put a fantastic write up together showing how to drop your transmission pan to service the magnets and screen .
    https://www.tacomaworld.com/threads...e-2nd-gen-transmission-pan-and-filter.726329/
    tacoman45, Rambo54, robssol and 3 others like this.
  6. Feb 25, 2017 at 3:29 PM
    Larueminati
    Larueminati Well-Known Member
    Western MA.
    2013 DCSB TRD 0FF-ROAD
    Anyone get a recent quote for what the dealers are wacking us for? I'm at 71,000 so its been on my mind, id want the full flush with the machine.
    Rambo54 likes this.
  7. Feb 25, 2017 at 3:35 PM
    dofartshavelumps
    dofartshavelumps Well-Known Member
    NH
    2015 SR DCSB 4x4 4.0 MT
    Those flush machines make me nervous for some reason, I have always had great luck with draining what I can, change filter, and add fluid method.
  8. Feb 25, 2017 at 3:54 PM
    gearcruncher
    The best flushing machines perform your flush with the pan removed . By far , its the best way to flush a transmission . If the pan is already off , there is no chance of stirring up metal and debris that,s on the pan magnets .
    A pan fluid drain also works well .Although a pan drain is only 1/4 of the fluid , it doesn't churn up the dirty contaminates in the bottom of the pan
  9. Feb 25, 2017 at 4:35 PM
    Kotah
    Kotah Well-Known Member
    TN
    2013 silver trd off-road Dc
    Oem running boards Window vent shades Oem bed mat liner
    The dealer told me you dont change the fluid how weird is that.
  10. Feb 25, 2017 at 4:43 PM
    stump jumper
    stump jumper Well-Known Member
    Bill
    Texas
    2017 Tundra 4x4 CM TSS
    Get your manual out and show them the maintenance schedule then do drain and fill yourself.
    Tex-Tac and robssol like this.
  11. Feb 25, 2017 at 6:46 PM
    gearcruncher
    Why go to the dealer to get a service performed ? They dont fix transmissions . Go to a reputable transmission shop . They know your trans inside and out and chances are , they will give you a better trans service than any dealer can
    tacoman45, Tatts521, Rambo54 and 4 others like this.
  12. Feb 25, 2017 at 6:59 PM
    Clearwater Bill
    Billy
    Largo Florida
    I always cut the OE recommendations for autos in half, but just do a drain/refill.
  13. Feb 26, 2017 at 5:29 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    It depends on the year. The owners manual in 07 says don't change. I'm at almost 180,000 miles on the factory fluid. I had a sample taken at 160,000 and tested. I was told it was still just fine and advised not to change the fluid. At this point I'll ride her till it quits on the fluid in there.
    It is heat that wears out ATF, not miles. If you tow heavy a lot, especially in mountains the fluid gets hot and should be replaced more often. If you only tow lighter loads, and rarely in mountains the ATF will last a very long time. I'd bet that 1/2 of the vehicle owners never change their ATF and it is nothing to see 200,000-250,000 miles on a transmission with the factory fluid in it. It is rare to see over 300,000 miles on one where the fluid has been changed religiously.
    If you tow a lot and let the fluid get hot then 30,000 mile changes are probably smart. If you ever let the fluid get over 240 degrees it needs to be changed ASAP even if you just had it replaced. If you can keep the fluid in the 190-210* range then it probably isn't economically feasible to ever change it.
    GilbertOz, Tex-Tac, Tatts521 and 2 others like this.
  14. Feb 26, 2017 at 5:55 AM
    Agentorange
    Agentorange Well-Known Member
    2010 White Tacoma TRD X-SP
    Carbon Fiber dash kit
    Ok this might be a stupid question but has anyone on here put a trans fluid temp gauge in there trucks. I only ask because my 07 Tahoe I traded for my current 10 Tacoma had a trans fluid temp gauge in the cluster. I gues what I am asking is it possible to install a gauge to onto the truck to monitor tran fluid temp.
  15. Feb 26, 2017 at 5:57 AM
    JMWolf96
    JMWolf96 Active Member
    Jim
    Severn, MD
    11 Tacoma TRD Sport
    Just got a quote from a dealership in VA, 286.00 for a full tranny flush. I am only at 72,000 and I do not tow anything, but was just looking around to see what it might run me once I decide to do it. I might do mine around the 80k mark.
    Larueminati likes this.
  16. Feb 26, 2017 at 6:00 AM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Lots of people do this by using an OBD-II display such as Ultragauge, Scangauge or just their phone paired with an OBD to Bluetooth or Wifi converter. Be sure whichever path you choose lets you configured it to display the transmission fluid temperature - a few of them do not. Many threads on here about displaying trans temperature.
  17. Feb 26, 2017 at 7:37 AM
    Agentorange
    Ok cool. Was just wondering. I dont tow anything so im not to worried about it. Also is there a fluid warning light for the trans if the level gets low.
  18. Feb 26, 2017 at 10:23 AM
    Ajay Naik
    Ajay
    Mountain View
    Very very helpful information guys! Thank you everyone!! Great discussion and tips!
  19. Feb 26, 2017 at 6:11 PM
    ZachPrerunner
    Southeast TN
    Yeah pushing it off on the next guy is the answer :smash:
  20. Feb 26, 2017 at 6:13 PM
    SoCOTaco
    SoCOTaco Well-Known Moron
    Mitchell
    Lakewood, CO
    2012 Tacoma TRD Off Road 4X4
    GFC, Fox 2.0's w/ Dakars, SCS BR6's, Fridge w/ Beer
    Sorry if I missed it, but do you have an auto or manual? My recollection is that the auto service is every 100k and the manual is every 30k.
