Transmission not holding on hills
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hlorange, Jul 22, 2009.
  1. Jul 22, 2009 at 12:36 PM
    hlorange
    hlorange [OP] Member
    Colorado
    08 Access Cab V6 Manual
    My '08 manual v6 will not hold on a hill without the parking brake on - engine off, in gear. It will pop back a foot or so each time. My dealer tells me this is "normal" but agrees it is unusual to be considered normal. Anyone else have this problem? Should I be pushing for warranty service on this or is it "an enhancement"?
  2. Jul 22, 2009 at 12:40 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Which gear are you leaving it in?
  3. Jul 22, 2009 at 12:42 PM
    hlorange
    Colorado
    Usually 1st but the same happens in reverse as well.
  4. Jul 22, 2009 at 12:48 PM
    oldtacomaguy
    oldtacomaguy four forty four
    Dave
    SE Conn.
    08 SR-5 4WD Impulse Red Pearl
    Alpine deck and amp, Polk speakers front and rear, Kenwood subwoofer, windows tinted to 20%, Sockmonkey decals, TSB, Eibach springs and Bilstein 5100's
    Maybe a dumb question, but why are you leaving it in gear with the engine off on a hill? Why not put it in park and set the brake?
  5. Jul 22, 2009 at 12:50 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    It's a manual.
  6. Jul 22, 2009 at 12:50 PM
    Dark Knight
    Dark Knight Well-Known Member
    Jeff
    NC/SC
    4Runner Trail
    ummmm manuals dont have "park"
  7. Jul 22, 2009 at 12:50 PM
    hlorange
    Colorado
    It's a manual transmission. Every other manual I've had (including earlier Tacomas) would hold it in place without the parking brake. This one won't, even on a minor slope like my driveway.
  8. Jul 22, 2009 at 12:51 PM
    oldtacomaguy
    Dave
    SE Conn.
  9. Jul 22, 2009 at 12:51 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Wow. Does it lurch once and act like it wants to roll the entire way?
  10. Jul 22, 2009 at 12:52 PM
    oldtacomaguy
    Dave
    SE Conn.
    Sorry, worked the night shift last night and didn't get enough sleep!
  11. Jul 22, 2009 at 12:54 PM
    hlorange
    Colorado
    Yup - it's lurch, stop, lurch, stop, lurch......Usually about a foot or less each time. Doesn't happen every time but does most times.
  12. Jul 22, 2009 at 12:58 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Sounds like first gear isn't "low" enough.
  13. Jul 22, 2009 at 1:05 PM
    jgguns
    jgguns Member
    You are right....that was Dumb.:D:D:D
  14. Jul 22, 2009 at 1:07 PM
    oldtacomaguy
    Dave
    SE Conn.
    Thanks, bro.
  15. Jul 22, 2009 at 1:12 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    First off you should never park a vehicle with a manual transmission, on an incline, without the parking brake applied AND the transmission in gear (first or rev).
    You should never leave the truck parked on an incline of any kind, with only the transmission in gear and the parking brake not engaged.
    If your parking brake is properly adjusted and you use these rules of thumb, you will not have an issue.
  16. Jul 22, 2009 at 1:13 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    OP, is the engine turning over or is the clutch slipping?
  17. Jul 22, 2009 at 1:19 PM
    SC4333
    Grant
    San Antonio, TX
    To add to my previous post, the reason your truck is moving a few feet at a time is because..
    When you leave the truck in drive and parked on an incline the only thing holding your truck back is the compression that has been built up in the engines cylinders. All engines leak down, but the leak down rate will vary depending on many variables. when your engine reaches a critical point at which the cylinder pressure is not enough to hold the vehicle from rolling, it will roll forward/back until the engine can build up enough compression again to hold the truck back.
    Also, when you turn the engine off, not all of the valves will be closed, so this further amplifies the problem by allowing a few of the cylinders to not hold cylinder pressure at all.
    To sum it up in a nut shell, never truck your engine to hold back your truck.
  18. Jul 22, 2009 at 1:23 PM
    hlorange
    Colorado
    Engine is off. I was just trying to avoid using the parking brake. As I first said, I've always (40 years of driving manuals) been able to leave my vehicle (engine off) on a slight incline without the parking brake. I'm guessing SC4333 would say I've been lucky; perhaps I have.
  19. Jul 22, 2009 at 1:35 PM
    Dark Knight
    Jeff
    NC/SC
    4Runner Trail
    why would you not use a parking brake on a manual in a inclined parked position as a safety precaution. that makes two us who think your lucky
  20. Jul 22, 2009 at 1:37 PM
    SC4333
    Grant
    San Antonio, TX
    Just trying to help out, and give some incite into what causes the 'lurch.'
    I've seen many a people come into the shop and say, "Well it was in gear??' Then you ask, "Was the parking brake engaged?" and you receive a reply something like this, "You know I cant really remember, I think it was but I don't always set it, the car holds its self in gear."
    I'm not trying to reticule you, or teach you how to drive, just prevent a headache. ;)
