transmission oil change - Ford XT-M5-QS Full Synthetic or MT-90?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Chris2009, Feb 25, 2022.
Which gear oil?
This poll will close on Feb 25, 2047 at 4:38 PM.
  1. Ford Fluid XT-M5-QS Full Synthetic Manual Transmission Fluid
    9 vote(s)
    37.5%
  2. Redline MT-90
    15 vote(s)
    62.5%
  1. Feb 25, 2022 at 4:36 PM
    Chris2009
    Chris2009 [OP] Well-Known Member
    Massachusetts
    2013 Reg Cab 4x4
  2. Feb 25, 2022 at 5:04 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Been running MT90 in my 6 spd since 15k (have 66k now), it certainly improved cold shifting vs the stock gear oil.
    Wulf and Chris2009[OP] like this.
  3. Feb 26, 2022 at 1:27 AM
    azzwethinkweiz
    azzwethinkweiz Well-Known Member
    Tucson, AZ
    2013 4x4 DCSB V6 6-Spd, TRD OR, Tow Package
    Ran both fluids in my 6 speed and they both seem better than what Toyota provides... I ended up sticking with the Motorcraft since its cheaper and I can get it locally but you cant go wrong either way.
  4. Feb 26, 2022 at 10:11 AM
    Chris2009
    Massachusetts
    2013 Reg Cab 4x4
    50/50 LoL….
    5 speed guys have any consensus?
    have to order it either way, can’t find either locally.
  5. Feb 26, 2022 at 2:24 PM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    I have been running MT90 in my truck for a couple of years now, and it has been fine. It is still stiff shifting the gears (1st to 2nd gear) in the mornings during the winter months, but usually gets better after a couple miles. I will say I can't shift into first until the truck is either completely stopped, or after driving an hour and then be able to shift into first around 5 mph.
    I would like to try the Ford fluid, but either the Ford or Redline gear oil, I have to order it, so I will probably stick to the MT90 when I change the trans fluid soon.
    Currygoat and Chris2009[OP] like this.
  6. Feb 26, 2022 at 2:38 PM
    Chris2009
    Massachusetts
    2013 Reg Cab 4x4
    The ad copy on the Ford stuff makes it sound pretty great. A few testimonials on this site make it seem able to work miracles. I’ll probably go with that….wish I’d researched a little more before having the dealership throw their standard GL5 synthetic at it. I assumed they’d know what works!
  7. Feb 26, 2022 at 3:50 PM
    Reggie4x4
    Reggie4x4 Well-Known Member
    Cole
    07 Red TRD OR V6 M/T 4x4
    Mostly stock
    For the 6spd only GL4 fluid is recommended.
    The Motorcraft fluid works well in my old girl. Used MT-90 prior, had it for the full 30k... It was pretty meh. MC seems to flow better.
    Chris2009[OP] likes this.
  8. Feb 26, 2022 at 3:55 PM
    wrightme43
    wrightme43 Well-Known Member
    Scottsville Kentucky
    17 Double Cab M/T TRD Offroad Blazing Blue Pearl
    Redline custom leather shift and e-brake boot. VFTUNE Super Full Otto cycle, octane learning, premium fuel.
    If you question the ford synth fluid, go to the miata forums. They are as, if not more, enthusiastic about the machines we all love. I had a very crunchy 2nd when I purchased my truck. I changed to the ford synth, and over 30,000 miles it has disappeared.
  9. Feb 26, 2022 at 4:01 PM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    You want GL-4 Redline MT-90. It actually healed a 3rd gear grind within 3 weeks of the change on mine 5 years ago (4.0 6-speed). After 5 years now, it is time for fresh fluid. I might do 1 qt Redline MT-90, and fill the rest in Redline MTL
    Do you know how to heal-to downshift? It helps by rev matching especially when cold
    Please note, do not put something stupid thin in just so it shifts great when cold. That will burn up your trans when its hot and you're pulling hills or trailers.
    This is the internet so people recommend stuff they have no business recommending.
    People saying Ford fluid, it better be 75w-90 or very close. Ford used to use ATF in their truck trans, that is NOT what you want
  10. Feb 26, 2022 at 4:35 PM
    Chris2009
    Massachusetts
    2013 Reg Cab 4x4
    Yeah, I’d never use anything that wasn’t factory spec: the Ford is GL4 75w90, full synthetic, meant specifically for manual trans and is supposedly very kind to the syncros and transmission in general.
    Both GL4 and GL5 75w90 are recommended for the 2nd Gen 2.7M/T 4x4. After a few days of research I’m thinking GL4 is what should have gone into this truck due the the cold winters in MA and the finicky Tacoma syncros.
    wrightme43 likes this.
  11. Feb 26, 2022 at 4:41 PM
    Chris2009
    Massachusetts
    2013 Reg Cab 4x4
    Still 50/50 in the polls!
    I appreciate all the responses fellas, thank you for taking the time.
  12. Feb 26, 2022 at 5:59 PM
    ARCHIVE
    Eric
    Ok that is good then. I recently had a bad experience with GL-5 in my beater 2000 ALH TDI Jetta manual trans, which calls for 75w-90. It shifted fine when I bought it, but I wanted fresh fluid in it, turns out it was 1/2 qt low. So I put some GL-5 Valvoline synthetic in it I had on the shelf (didn't have MT-90), well it shifted terrible afterward. So I ordered up some MT-90 and swapped it out, and the shifting definitely improved.
    My feeling is a previous owner put some lower viscosity stuff in it, so its initial cold start up shifting was good, but that is what can hurt gears in a trans under load
    Chris2009[QUOTED][OP] likes this.
  13. Feb 26, 2022 at 6:28 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I've never run either but pretty much just run Lucas in mine now. Mine is a 6 speed manual.
    When I first switched from the stock flavor, it was immediately better then got even a little better over time. If it's not great immediately, give it a couple of weeks.
    Do a little research, it's not too tough to do yourself. Just make sure you don't strip out your drain and fill plugs if you do it yourself. They are threading into the aluminum of the transmission and that material is soft.
    I use a little Teflon tape on the threads of both.
  14. Feb 26, 2022 at 7:05 PM
    wrightme43
    Just scroll down and read the reviews on Amazon about the synthetic Ford fluid.
    I used it my NB. It is amazing.
  15. Feb 26, 2022 at 7:19 PM
    Homeline
    Homeline Well-Known Member
    2013 Access Cab 5-Lugger
    2" Leveling Kit, TRD skid plate, 16" Jeep wheels, Katzkin leather seats w/heaters, jump seat delete
    I have a 2wd 2.7l w/5spd. At 100k I changed to RL MT90. It did improve shifting. It's still stiff in cold temps, but better. Only way I can get back into 1st when rolling to a stop is to double clutch.
    Also added a 2" extension to the shifter. Even with my long arms, the factory setup was too low.
  16. Feb 26, 2022 at 7:26 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    Most manual transmissions don't like going into 1st when rolling, 1st should only need to be used from a dead stop anyway.
    I usually hit 2nd or 3rd on a rolling stop, only go to 1st after I'm stopped.
  17. Feb 26, 2022 at 7:41 PM
    Homeline
    Agreed, many don't. But my old B2000 didn't mind it, neither did a Saturn I had for a while. With the Tacoma it is something I've had to adjust to. Bit of a pain in stop/go slow traffic, and going into 2nd just lugs the engine.
    Curious, is the MT in my 2nd gen the same as 1st gen?
  18. Feb 26, 2022 at 8:12 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    They have different designations in the service manual @gearcruncher may be able to tell you the differences between them, he has a thread on the R155(F) here
    1st gen:
    W59 2wd 2.4l engine only
    2.7L & 3.4L R150 (2wd), R150F (4wd)
    2nd gen:
    5 spd: R155 (2wd) R155F (4wd)
    6 spd: RA60 (2wd) RA60F (4wd)
  19. Mar 16, 2022 at 6:03 PM
    Chris2009
    Massachusetts
    2013 Reg Cab 4x4
    Went with the Ford stuff. Pricey but seems to be working MUCH better. Will know definitively if we’re unlucky enough to get another cold spell. Happy I went ahead and did the swap in the end. :thumbsup:
    winkel and wrightme43 like this.
  20. Mar 16, 2022 at 7:02 PM
    wrightme43
    You will love it. My crunchy second is now smooth as silk.
