Transmission oil change
Discussion in '2nd Gen. Tacomas (2005-2015)' started by geochurchi, Sep 2, 2013.
  1. Sep 2, 2013 at 1:13 PM
    geochurchi
    geochurchi [OP] Well-Known Member
    NH
    Tacoma
    How do I change the oil in 2012 Taco automatic transmission,is there a drain plug?
    Thanks
  2. Sep 2, 2013 at 1:14 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
    You don't.
    No plug.
    Progress? :eek:
  3. Sep 2, 2013 at 1:24 PM
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
  4. Sep 2, 2013 at 1:36 PM
    Floki
    Floki Old Sheepdog
    St. Louis, MO
    2024 TRD Sport
    Mud on the tires
  5. Sep 2, 2013 at 1:44 PM
    jw1983
    Alberta
    When I bought my 11' BCLB(Before my Access) I had asked them about the Tranny flush(wasn't in the maintenance book) and the Customer Service Rep wasn't sure. They brought over a tech and he told me that, "they could change it if I wanted it done,it's not recommend by Toyota to do so". Members on this board have done their own tranny flushes.
    You can do what my roommates did, just never change it. Her car is 8 years old(bought new) now and almost 200,000 km's and never had any tranny issues. I tried to tell her and her husband but it's not "important" enough apparently. :) Glad it ain't my car.
  6. Sep 2, 2013 at 1:48 PM
    wildcats
    wildcats Well-Known Member
    13 DCSB Sport
    I believe you're supposed to change it at 60k miles. Doesn't sound too bad to just drop it and refill. You can either keep track of the oil you remove and replace it with that amount. Or you have to have it at the proper temperature and it should just trickle out of the check plug, this way is more difficult but is the proper technique.
  7. Sep 2, 2013 at 2:03 PM
    Kirk1589
    Kirk1589 Well-Known Member
    Dave
    Sticks-RI
    03 SR5 Off-Road
    Pasti-Dip Grille, K&N drop-in, Magnaflow 14", Custom tail light mod, Fog light mod, diff vent mod, Alpine Components, Sequoia JBL radio
    You can change it. Us techs are smarter than any person in the dealership about what you can and cannot do to the vehicle. Yes you don't have a dip stick, many new vehicles don't. Every 30k I recommend a tranny service. At Ford this is a full flush. When you JUST drop the transmission pan you only get 75% of the fluid out, the converter is still full. But you get to change the filter. Some will argue that flushes are bad and dropping the pan is bad. Neither are true. They are both just as good as the other. With a flush your not changing the filter but you can have them do that just more money. When I flush is done all they do is pull the lines going to the cooler and connect it to the flush machine. Fill the tank with the proper fluid, start the vehicle, push FLUSH that is it.
  8. Sep 2, 2013 at 2:24 PM
    92dlxman
    92dlxman drinking whats on sale
    Kevin
    Visalia, CA
    08 access 4x4 4.0 6-gear
    5100s, ome884s, wheelers aal kit, and some rustoleum
    I understand that it should be changed every 100k miles. maybe that is just with the older models?
  9. Sep 2, 2013 at 2:29 PM
    jw1983
    Alberta
    Haven't these engines been the same ones used since 2005?
  10. Sep 2, 2013 at 2:51 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    According to Toyota it's 60,000 or 72 months (which ever comes first) for hard use such as towing (i'd do it even for normal use.) The Chiltons manual says every 30,000 miles or 24 months.
  11. Sep 2, 2013 at 3:01 PM
    bjboucher
    bjboucher Mama says Tacoma World is da devil!
    Brad
    San Antonio, Texas
    Former 2012 DCLB 4x4 SR5 Texas Edition
    OME complete kit w/ 885s on Nitrocharger Sports, 1/4" spacers, Dakars w/ Nitrocharger Sports, LR UCAs, 265/70-17, Duratracs, G4 Elite tonneau, Weathertech Window Deflectors, Weathertech digital floor liners, factory JBL/Entune, rear differential breather relocate.
    There is a drain plug....I've seen threads where folks accidentally drain their transmissions instead of their oil. The two are fairly close to each other.
    How many miles are on your truck? A 2012 and it's time for a transmission fluid change already?
  12. Sep 2, 2013 at 4:55 PM
    92dlxman
    Kevin
    Visalia, CA
    yes. and transmissions for that matter but thought maybe Toyota may have increased confidence in the a/t and its fluid since 05.
    I have heard from other newer model year owners that the fluid is lifetime fluid. swear I thought I heard 100k somewhere years ago though.
    im not an a/t owner. if I was I would know for sure. my slush-box gets it every 30k no matter what any literature says
