Transmission oil change
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaislife, Sep 9, 2019.
  1. Sep 9, 2019 at 6:05 PM
    Tacomaislife
    Tacomaislife [OP] Well-Known Member
    Texas
    2002 tacoma trd
    I was wondering if I could use amsoil trans fluid instead of Toyota trans fluid
  2. Sep 9, 2019 at 6:50 PM
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    I wouldn't...................
  3. Sep 9, 2019 at 7:02 PM
    eon_blue
    Azusa, CA
    Usually people go with something other than the Toyota fluid because the Toyota stuff is expensive, but Amsoil probably costs more so I'd just stick with the Toyota stuff.
  4. Sep 9, 2019 at 7:18 PM
    c0climber
    c0climber Well-Known Member
    Northern Colorado
    2001 Tacoma
    The answer is yes you can, the better question is why would you?
  5. Sep 9, 2019 at 8:27 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    You can do anything your little heart desires.
    However, in this case I'd just stick to what the factory recommends.
    Bishop84 likes this.
  6. Sep 9, 2019 at 11:10 PM
    opteron
    opteron Well-Known Member
    whittier, CA.
    2003 DB 4x4 SR5
    Leer camper, bug-rug, fox suspension 2.0 rear, fox 2.5 front, BAMF sliders and LCA, TRD fake 3 piece rims
    Had dealer change out it out for 180 they used 13 qts according to the invoice.
  7. Sep 10, 2019 at 12:29 AM
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    Use Dex 2 or 3 type and whatever brand you want. You don’t need OEM and it won’t hurt.
  8. Sep 10, 2019 at 3:19 AM
    Clearwater Bill
    Billy
    Largo Florida
    From the 2002 owners manual.............
    AUTOMATIC TRANSMISSION
    Fluid capacity (drain and refill), L (qt.,
    Imp. qt.):
    Two−wheel drive models except Pre
    Runner
    Up to 2.4 (2.5, 2.1)
    Four−wheel drive models and Pre Runner
    Up to 2.0 (2.1, 1.8)
    Fluid type:
    Automatic transmission fluid D−II or
    DEXRONIII (DEXRONII)
    TRANSFER
    Oil capacity, L (qt., Imp. qt.):
    1.0 (1.1, 0.9)
    Oil type:
    Gear Oil API GL−4 or GL−5
    Recommended oil viscosity:
    SAE 75W−90
    You'll not find that on shelves in stores anymore. It's been superseded several times.
    You'll want to look for Dexron VI or a fluid that specifies it's backward compatible with Dexron II/III
  9. Sep 10, 2019 at 12:06 PM
    TacoJohn4x4
    Central Valley
    2002 Tacoma DC 4x4
    Also ATF Dex/Merc labels are Dex 3.
  10. Sep 10, 2019 at 12:12 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    If they used that much, then they made sure to drain out all the old fluid, and use new fluid to push the old stuff out. Good job.
    c0climber likes this.
