transmission oil leaks
Discussion in 'Technical Chat' started by lifted tacoma, May 6, 2012.
  1. May 6, 2012 at 6:15 PM
    lifted tacoma
    lifted tacoma [OP] Member
    edwin
    hawaii
    lifted pre-runner
    6" fabhtech
    what's up everyone i am new to this forum. i dont know if i posted this question in the correct topic. my truck running good all day long underway home the truck loss power and heard a hissing sound when press the gas pedal until the completely loss power. oil leaking under the truck, so i have it tow when i get home i start the truck to see where the leaks coming from the leaks coming from between the transmission and engine housing, beffore i take it apart i would like to makesure i assume the oil seal is there anyone experience this issue.
  2. May 6, 2012 at 10:25 PM
    SampleFool
    SampleFool Three Percenter
    Ga
    Silver
    08 off-road
    Never had that problem, but it sounds like if it is engine oil you have a rear main seal bad. Just did one on a hmmwv and it was not too bad. But I also am a mechanic, I did not experience any hissing sounds or loss of power.
  3. May 7, 2012 at 12:42 AM
    lifted tacoma
    edwin
    hawaii
    lifted pre-runner
    6" fabhtech
    thank you, eventually i didnt lost any engine oil. i lost my transmission oil.
  4. May 7, 2012 at 1:07 AM
    winL
    winL Well-Known Member
    Bay Area, CA
    PreRunner
    Leer 100R Cap, OEM Hood Protector, Bilstein 5100's @0, Wheeler's 3leaf AAL no TSB, Replaced oem OL, OME 885, Pioneer AVIC-D2
    subd
  5. May 9, 2012 at 1:18 PM
    SampleFool
    Ga
    Silver
    08 off-road
    Well then it could be your tranny pump seal, I didnt look if your auto or manual. Either way it is a seal that should be rather easy to drop and replace in a day.
  6. May 24, 2012 at 2:41 AM
    lifted tacoma
    edwin
    hawaii
    lifted pre-runner
    6" fabhtech
    yes, it was the pump seal. thank you
