Transmission oil sample
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Skydvrr, May 14, 2021.
  1. May 22, 2021 at 8:09 AM
    #41
    Skydvrr
    Skydvrr [OP] IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    I'll keep up with my spill n fills. The old oil is definitely darker and slightly burnt every change I've done.
    Lt. Dangle likes this.
  2. Jun 29, 2021 at 12:56 PM
    #42
    DrRoboto
    DrRoboto Well-Known Member
    David
    Salt Lake City, UT
    <s>2017 AC Off-Road</s>
    GoFastCamper. OME 886. Medium Dakars. SSO slimline bumper + Warn VR10-S. OGE dual battery system. Mobtown skids.
    The recommended maintenance schedule states 120,000 miles for the first replacement of ATF. I am skeptical. How far are folks actually driving before replacement?
    SLeeper512 likes this.
  3. Jun 29, 2021 at 1:11 PM
    #43
    brian2sun
    brian2sun Well-Known Member
    California
    ‘21 TRD OR DCSB ‘17 4Runner Limited ‘97 4Runner SR5
    You have way too much time on your hands.
    JustJon likes this.
  4. Jun 29, 2021 at 1:50 PM
    #44
    Skydvrr
    Nick
    YMH
    Black '17 OR
    My trans temps are routinely high. If you're skeptical about anything, it should be a one size fits all maintenance schedule. This is just what I do w my truck in my situation.
    Dirk Diggler likes this.
  5. Jun 29, 2021 at 1:50 PM
    #45
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Thanks for the feedback! Although my 6-10's would disagree with you. :thumbsup:
    Dirk Diggler and Tacospike like this.
  6. Jun 29, 2021 at 2:11 PM
    #46
    Illini Tacoma
    Illini Tacoma Well-Known Member
    2016 Dark Red Double Cab Short Box
    I've seen similar trans. temps as Skydvrr has reported here on our truck and I've got a 11" X 11" TruCool trans. cooler installed. I know the cooler is doing it's job because I've felt the inlet (hot) and compared it to the discharge hose on the aftermarket cooler and there is a clear and unmistakable difference in temperature. I see TC temps. over 200° F on days when the ambient temperature is 80° F. Unbelievable but true.
  7. Jun 29, 2021 at 2:15 PM
    #47
    Tacospike
    Two Trucks
    My feedback,
    You’re a cool dude in my book!
    :cheers:
    Skydvrr[QUOTED][OP] likes this.
  8. Jun 29, 2021 at 2:15 PM
    #48
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    I am an ex-submariner and preventative maintenance was nothing short of a religion on the boat. But 4 transmission drain and fills in 65,000 miles feels a bit excessive! I guess if done correctly it certainly won't hurt anything to swap the fluid out that often, but I really don't think you are buying your gear box any more time in doing so. But hey, your time and your money so have fun!
    JustJon and Skydvrr[OP] like this.
  9. Jun 29, 2021 at 2:21 PM
    #49
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    This is pretty much what I have resolved to do myself. Just change a few qts. every oil change or so. Keeps it from going bad and it's not exactly hard to do this way.
  10. Jun 29, 2021 at 2:31 PM
    #50
    Skydvrr
    Nick
    YMH
    Black '17 OR
    200 is normal operating temp for me on most days. Now that the ambient has gone up just drivin down the freeway in 5th is over 200. Any hint of a load and it's 210+
  11. Jun 29, 2021 at 2:31 PM
    #51
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Haha you rule buddy. Hope you're stayin cool up there!
    Tacospike[QUOTED] likes this.
  12. Jun 29, 2021 at 2:32 PM
    #52
    Kevin Jones
    Kevin Jones Well-Known Member
    Kevin
    Va
    1996 Tacoma - 2018 Tacoma
    Interesting as I've had dozens of vehicles with A/Ts over the years, drove them many miles, never had the A/T fluid changed in any and have never had a problem with an A/T.
    Maybe, changing your fluid too much is causing your problems. ;)
    Kev250R and Skydvrr[OP] like this.
  13. Jun 29, 2021 at 2:32 PM
    #53
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Keep in mind 1 spill n fill is like 3 quarts. Total sys capacity is like 12 I believe.
    SLeeper512 and Lt. Dangle like this.
  14. Jun 29, 2021 at 2:33 PM
    #54
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Yeah. It's basically like a 30-45 min job even with removing the mid skid. Not too bad.
    Lt. Dangle[QUOTED] likes this.
  15. Jun 29, 2021 at 2:33 PM
    #55
    Skydvrr
    Nick
    YMH
    Black '17 OR
    I'll let you know in 200k miles!
  16. Jun 29, 2021 at 5:57 PM
    #56
    Dirk Diggler
    Dirk Diggler Under the Stun Gun
    Columbus, GA
    2017 MGM OR DCSB
    @Skydvrr have you pulled your pan and done your filter before ?
  17. Jun 29, 2021 at 6:01 PM
    #57
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Nopers. I should though. I had super small synchro brass in one of my changes. From what I heard it's just a screen anyway?
  18. Jun 29, 2021 at 6:03 PM
    #58
    Dirk Diggler
    Columbus, GA
    2017 MGM OR DCSB
    Not sure I dented my pan and am gonna pull it and replace it. Might as well check the screen while I'm in before I put a new gasket on seal it up and full it up
  19. Jun 29, 2021 at 6:09 PM
    #59
    maxmk8
    maxmk8 Well-Known Member
    2022 Electric Lime M/T Taco
    What app is this ?
  20. Jun 29, 2021 at 6:11 PM
    #60
    maxmk8
