Transmission oil
Discussion in 'Technical Chat' started by Bad Sunday, Dec 4, 2011.
  1. Dec 4, 2011 at 8:34 AM
    Bad Sunday
    Bad Sunday [OP] New Member
    Need help, I remove the wrong plug to change engine oil and remove about 1.5 qt of Transmission fluid. What should I do.?
  2. Dec 4, 2011 at 8:35 AM
    Brunes
    Brunes abides.
    Rotorhead
    Get a tow to a dealership and get them to replace the fluid?
  3. Dec 4, 2011 at 8:41 AM
    Frankoo1234
    Frankoo1234 Well-Known Member
    OC
    Double Cab 05 Taco PreRunner
    Running boards, Tint
    ether do what Brunes said and get a tow.. or look up the writeup on how to drain and fill autotrans fluid... have someone drive you(not in your truck) and pick up the required amount of fluid... fill it yourself... BUT i heard its tough to check if you have the right about of fluid somekind of temp check is needed right guys??
  4. Dec 6, 2011 at 6:58 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    If the tranny fluid is in a clean container, just put back in what came out. That will get you functioning again, then you need to decide if you want to check the fluid level the right way.
  5. Dec 6, 2011 at 7:01 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
  6. Dec 6, 2011 at 7:21 AM
    Jdaniel1274
    Jdaniel1274 Well-Known Member
    Daniel
    Orange County, Ca
    01 DC TRD 4X4
    PIAA lights, OMD leaf spring mod, magna flow muffler, oil filter relocation kit
    Go buy 2 quarts of transmission fluid, check your owner's manual for the type of fluid. Pour in 1.5 quarts, check the transmission dip stick, to see that you added enough. and your good to go.
  7. Dec 6, 2011 at 7:35 AM
    Lurkin
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    "transmission dip stick", spoken like a true Gen1 guy!! :p:p
