Transmission on stopping, makes a thump
Discussion in '1st Gen. Tacomas (1995-2004)' started by vapovick, Aug 19, 2010.
  1. Aug 19, 2010 at 1:08 PM
    vapovick
    vapovick [OP] Active Member
    1999 Toyota Tacoma 4x4
    I took it to the dealer and he said its normal. Anyone out there with experience on this?
    When I come to a stop, the transmission sounds like its dis-engaging or something. It doesn't appear to be causing an issues, and its been doing it the 7 years I have owned it, but I just want to know if anyone else out there has seen/heard this type of behavior?
    1999 Tacoma, AUTO trans, 4x4 2.7liter
  2. Aug 19, 2010 at 1:15 PM
    wooddogg922
    wooddogg922 Well-Known Member
    15 DCLB TRD Sport PreRunner
    Is it the tranny, or the dreaded Tacoma axle wrap?
  3. Aug 19, 2010 at 1:21 PM
    misterquad
    misterquad Well-Known Member
    Shawnee, KS
    I have a theory that I have been testing. I believe it is the transmission shifting down into 1st gear when you completely stop. To test my theory, I shift into neutral as I am stopping. After I stop for a second or two I shift the transmission from neutral into drive. I had been able to repeat the same feeling. And basically satisfied myself that it is normal downshifting.
  4. Aug 19, 2010 at 1:34 PM
    vapovick
    Thanks for the responses everyone. Like I said its been doing this for almost 7yrs without issue. More of a worry really. BTW what is Tacoma axle wrap?
  5. Aug 19, 2010 at 1:38 PM
    misterquad
    Shawnee, KS
    Have you ever done a burn out and felt the rear end hop? That is caused by axle wrap. The leaf springs bend/twist under torque and spring back into shape causing this jumpy feeling.
  6. Aug 19, 2010 at 2:26 PM
    vapovick
    I am only seeing this behavior when I stop, not on 'take off' I am starting to believe its more of dis-engage than anything.
    Again thanks to all for the responses.
  7. Aug 19, 2010 at 9:39 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If you are interested in finding out more about what folks here refer to as axle wrap, there has been a lot written about this topic. Here are some interesting threads, and a good place to start.
    http://www.tacomaworld.com/forum/1s...rward-when-auto-trans-shifts.html#post1900827
    http://www.tacomaworld.com/forum/1st-gen-tacomas/108316-goodbye-axle-wrap-mod.html
    http://www.tacomaworld.com/forum/1st-gen-tacomas/104847-damage-wear-axle-wrap.html
