Transmission or ABS sensors?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by cessnasqueak03, Feb 11, 2025.
  1. Feb 11, 2025 at 10:53 AM
    cessnasqueak03
    cessnasqueak03 [OP] New Member
    J
    2014 Tacoma TRD
    Hi everyone. I have a '14 Tacoma TRD with over 200k miles and I have an issue none of my shops can figure out.
    It will go into gear but will stop suddenly. This morning it's raining and my truck stopped me in the middle of the highway, squealing tires and all. I'm to the point of thinking it's not the transmission rather the ABS sensors. It's intermediate and not throwing any code (other than oil change) Has anyone else dealt with this? Am I on the right path?
    Also, is there a recommended maintenance book other than the one that came with the truck?
    thank you.
  2. Feb 11, 2025 at 10:55 AM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Were you pressing the brake when it happens?
    If not, the ABS shouldn’t come one.
    Is your ABS light on?
    The check engine light on?
  3. Feb 11, 2025 at 11:10 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Ujoints and center bearing or broken rr parking brake cable, maybe.
  4. Feb 11, 2025 at 9:06 PM
    Pigpen
    Dan
    Northwest Montana
