Transmission or diff slips while taking slow sharp turns
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TacoTRDSport4.0, Feb 26, 2017.
  1. Feb 26, 2017 at 4:39 PM
    TacoTRDSport4.0
    TacoTRDSport4.0 [OP] Member
    2010 burgundy red Tacoma TRD Sport 4.0
    i just changed the rear diff fluid on my 2010 Tacoma red sport which has the LSD of course. I put 3 quarts of valvoline full synthetic 75w-90 in it, i was reading up on LSD and also put in trans x also I changed the ATF fluid as well to valvoline max life since the WS fluid is supposed to be horrible. Everything was good for a couple miles but then when I take a turn at low speed feels and sounds like either the diff is slipping or the transmission is somehow in neutral then eventually grips and starts working again. I put in the specified amounts and until the fluid overflowed. 3 quarts gear oil and also a little over 3 quarts of ATF fluid. I flushed out the diff fluid because I kept reading up on what was wrong and came to find out my year does not have mechanical LSD so I did not have to put in the friction modifier, so I flushed the rear diff and decided to go with a different gear oil, so I went with the valvoline full synthetic 75w-140. This still did not help with the situation. So I'm aiming at the transmission at this point. Does anyone know of what maybe happening and what a fix maybe? I seen you have to check the level between 115 and 130 degrees F which I did not check at a specific temperature at the time.
  2. Feb 26, 2017 at 5:01 PM
    gearcruncher
    Canadain bumper technician
  3. Feb 26, 2017 at 5:23 PM
    TacoTRDSport4.0
    Did not do that, I added what was specified by the Haynes manual, kept adding until the fluid started to pour out the overflow plug and capped off. Transmission was somewhat warm but was not operating temperature
  4. Feb 26, 2017 at 5:28 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    definitely not your rear diff. Even if it was a mechanical LSD type with a fucked up oil change that killed the clutch pack in the rear diff, there is in no way shape or for it can "slip" the way you are mentioning.... a killed clutch pack in a LSD will just yeild a conventional open diff.
    Needless to say you messed something up with your trans.
    1. STOP DRIVING IT.
    2. Follow the proper procedure to fill it up.
    3. Fill it up with OEM Toyota WS fluid.
    4. At this point because you put 3 quarts of something else in the trans... you are going to need to do a full drain and fill. 11-13qts.
  5. Feb 26, 2017 at 7:39 PM
    sawed off
    sawed off Well-Known Member
    Randy
    Idaho
    Prerunner 2wd 2.7 SR5
    Engine has to be running when filling trans. Its low!
  6. Feb 26, 2017 at 10:20 PM
    TacoTRDSport4.0
    Got it, thanks guys I'm going to put some more in tomorrow and run through some tests. I'll check back in tomorrow.
  7. Feb 26, 2017 at 10:34 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
    I swear i read this same thing posted by brandon something or other.... his was trans fluid issue too.
  8. Feb 26, 2017 at 10:49 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
  9. Feb 27, 2017 at 5:24 PM
    TacoTRDSport4.0
    Everything is good to go now! Added about another quart pretty much. Waited till the temp got between the two temps while running and in neutral, then added till I seen it pour out the overflow hole! Thanks everyone!
  10. Feb 27, 2017 at 5:33 PM
    TacoTRDSport4.0
    Also I have noticed the truck shifts a hell of a lot better with the valvoline max life than the WS fluid.
    gearcruncher likes this.
  11. Mar 1, 2017 at 3:09 AM
    07 sport 4x4
    07 sport 4x4 Well-Known Member
    Blake
    Southeast
    2017 Duramax
    Lots of people here running the valvoline maxlife ATF, I haven't heard of anybody having any issues with it in these transmissions.
