Transmission or injector problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lex137, Apr 4, 2017.
  1. Apr 4, 2017 at 8:16 AM
    Lex137
    Lex137 [OP] Member
    Alex
    2017 black Tacoma TRD Off Road
    None that are cool enough to list
    So I have a 17 trd off road and I have noticed that when the rpm is between 1-15k lightly stepping of the gas pedal it sputters. Like it's not getting fuel or it's deciding weather to shift. I notice it going around 30mph, but last night I was going around 40mph and it did it to the point where I had the gas pedal halfway down and it did nothing rpm didn't move nore did mph. My sister was in the car and said she could feel it lagging when I mentioned it. I called to bring it in Friday at the dealership.
    Also I did my first maintenance at about 1000 miles, so hopefully they did it right and checked all the fluid levels.
    I was hoping maybe someone here will have a fix that I can pass on to the dealer so I don't have to keep taking it back and sell it due to the problem. I really love this truck and want to keep it for a long long time.
    I will make sure they check the transmission level again! Thanks for any help or advice short of sell the truck.
  2. Apr 4, 2017 at 8:20 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Make sure the intake piping is tight around the maf sensor; maybe a slight vacuum leak
  3. Apr 4, 2017 at 8:23 AM
    Lex137
    Lex137 [OP] Member
    Alex
    I will check that out today, thank you Steve!
  4. Apr 4, 2017 at 8:29 AM
    WHPLSH3
    WHPLSH3 Fortified with horsepower-adding goodness...
    Vance
    Alberta
    Supercharged Spruce Mica 6spd 4x4
    Build thread coming soon!
    Engine control modules are programmed to shut fuel injectors off if the engine is in "coast down" mode for a period of time.
    Having the accelerator barely pressed will cause the truck to act exactly as you describe if you're going down a slight hill or slowing down for a residential area or something...
    Pittrider likes this.
  5. Apr 4, 2017 at 8:31 AM
    Herniator
    Herniator Well-Known Member
    Edmonton
    2016 Toyota Tacoma TRD Sport
    chrome valve stems covers
    Could be bad gas.
  6. Apr 4, 2017 at 8:41 AM
    Lex137
    Lex137 [OP] Member
    Alex
    I don't think so, I only get it from newer gas station and look to make sure the refueling part is higher than the rest of the concrete. It doesn't do it outside of 2k rpm
  7. Apr 4, 2017 at 8:45 AM
    Pittrider
    Pittrider Pitty, those needing correction.
    Greg
    B.C.
    2016 MGM LTD LB
    Do you need to know, or care?
    Does it sputter, or feels more like a delay? If a delay, that's normal for this configuration as the transmission will be in a high gear and there is a delay kicking down to a lower gear. Either give it a lot of gas (still delayed, but seems to be a little quicker) or I'd recommend trying it with ECT on and see if there is a difference. If there is a difference, it's because with ECT off, the truck is in 5th or 6th gear at 30 mph at 1000rpm. Basically acting like an old dog.
    jsinnard, Bagow and JasonCz like this.
  8. Apr 4, 2017 at 8:48 AM
    Herniator
    Edmonton
    Sorry, I don't know what you mean by having the refuelling part higher than the rest of the concrete.
  9. Apr 4, 2017 at 9:25 AM
    Lex137
    Lex137 [OP] Member
    Alex
    It seems to
    It seems to only do it when I'm accelerating and driving slow like a grandma.
    Where the tanker puts fuel into the tanks at the gas station they look like water valve coves there no bigger than 8 inch round circles. They should be raised maybe 2-3% grade from the rest of the surface so snow or rain doesn't pool on top of them or collect there and form a small pond. It helps keep the water out of the gas.
  10. Apr 4, 2017 at 9:35 AM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Then they will tell you it's normal. Use the ECT button, you'll notice a big difference.
    Garyji likes this.
  11. Apr 4, 2017 at 9:40 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    ECT and "S" mode. It'll be fine. Gotta drive it where it likes it.
    G.
  12. Apr 4, 2017 at 9:58 AM
    Lex137
    Lex137 [OP] Member
    Alex
    What are the effects of using the ECT mode all the time, besides maybe mpg going down?
  13. Apr 4, 2017 at 10:01 AM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Nothing, just changes your shift points, as far as I know. Some talk about changing the fly by wire gas pedal settings, but I'm not sure if that's real
  14. Apr 4, 2017 at 10:01 AM
    Garyji
    Gary
    I live on back country roads with some hills. I use it all the time and always get between 18-20 MPG's. Switch it off on the highways. I use "S" mode for engine braking as well. Have for years.
    G.
  15. Apr 4, 2017 at 10:04 AM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    I do this as well, it's a good habit to have and saves the brakes. Not to mention us who have to drive on ice, it's a life saver.
    Garyji[QUOTED] likes this.
  16. Apr 4, 2017 at 10:33 AM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    Ok brace yourself.... 'it's normal'...
    Well it isn't, but toyota had no fix for it yet
  17. Apr 4, 2017 at 10:41 AM
    Lex137
    Lex137 [OP] Member
    Alex
    So you just downshift instead of braking to slow down?
  18. Apr 4, 2017 at 11:02 AM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    Toyota uses it for downhill descents when you are in auto. I've noticed it when going down steep hills over around 45mph. Tap the brake two or 3 times to lower your speed and the tranny will pick a lower gear to help with the braking. There are a couple hills around my area that it happens on all the time. It will stay in that lower gear until you are back on the gas or drop to a even lower gear on the brake.
  19. Apr 4, 2017 at 11:17 AM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    I have detected a difference in engine response to the gas pedal in ECT. There is less of a lag gap between when you start pressing and completely off.
    Herniator likes this.
  20. Apr 4, 2017 at 11:28 AM
    Pittrider
    Greg
    B.C.
    2016 MGM LTD LB
    It's possible, it definately feels more responsive. What I haven't tried is putting it in S mode, bring the RPMs up to where it would be if in ECT mode, and then see if the pedal feels more responsive or has the same lag. Basically what I'm saying, does it feel more responsive because of RPM, or has the pedal settings changed? Not a scientific approach, or a Toyota Engineer.
    Guess it could be both. I'm still unsure whether I feel a difference off the line, but ya, lots of speculation.
