Transmission over full
Discussion in '3rd Gen. Tacomas (2016-2023)' started by wild toyote, May 19, 2017.
  1. May 19, 2017 at 6:59 AM
    wild toyote
    wild toyote [OP] Member
    92 Volvo 240
    2017 TRD sport DCLB automatic transmission, Had my dealer do a transmission fluid check, they said it was over filled and technician corrected the level. Has anyone heard of them being over filled? Truck was dropped off at the dealer by the wife at 10am, they called at 1:30pm same day and said it's ready... I don't think it was properly checked.
  2. May 19, 2017 at 7:12 AM
    Chazmann
    Chazmann A/C TRD Sport V6 4x4 6-MT
    That's interesting.
    I have a TRD Sport 6-MT also.
    What made you to conclude that dealer did not check properly?
  3. May 19, 2017 at 7:13 AM
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    Maybe the tech didn't let it properly cool down?
    kahanabob likes this.
  4. May 19, 2017 at 7:22 AM
    wild toyote
    92 Volvo 240
    It's an automatic transmission, I'm thinking they didn't give it time to cool down to the proper temperature range, and now my transmission is likely even lower on fluid.
  5. May 19, 2017 at 7:46 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    There was a post here were the dealer told the OP they would suck out all the fluid to get the most accurate measurement its ridiculous!
    And there have been countless postings of one dealer saying it needs mo' and some saying it need less.
    Do you really want someone checking the ATF level on your truck?? I mean we trust that the wheel bearing, center propeller shaft bearing are ok, and they generally last 100k without ever being touched,. It's daunting to think the ATF would be low.
    It's sealed for a reason, and for the long run, and we haven't seen any issues with these going back to the 2nd Gen. They're just not failing due for the lack of ATF.
    If a transmission fails, is usually a part failure or miss assembly and not for the lack of ATF.
    Having said that the process of a manual check is actually very simple, almost like checking with dipstick where the temp has to be in range, and yet many screwed them all up, and that's why they sealed them.
    I'm not about to let anyone near my ATF as long as there are no leaks and it works as intended, but that's just me.
    Cheers!
    CusterFan, minium and Garyji like this.
  6. May 19, 2017 at 8:00 AM
    wild toyote
    92 Volvo 240
    If I had access to the transmission temperature sensor I could check it my self, otherwise I would need the Toyota transmission fluid check tool kit!
  7. May 19, 2017 at 8:54 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    No you don't.
  8. May 19, 2017 at 9:25 AM
    BlkTaco47
    BlkTaco47 Unhinged
    2016 Black AT DCSB 4x4 TRD
    JL Audio C2690tx Speakers Alpine MRV-F300 JL Audio 10" Sub - Full length Ported Sub Box Kicker Tweeters BFG KO2's 265/70/17 Tint N-Fab Bars Husky WB Mats AVS Visors Console Divider Tacoma Tonneau Cover ALL PRO 1.5" wheel spacers aFe CAI w/ Dry filter TRD Wheels Custom Remote Starter TRD Pro Grille ROAV Dash Cam 3" RC Lift Turn-down exhaust pipe TRD PRO Shift Knob vF Tune
    nope
  9. May 19, 2017 at 9:44 AM
    wild toyote
    92 Volvo 240
    Well how would you tell what temperature the fluid is at? To do a hot check I was under the impression Toyota uses the transmission fluid check kit that they had developed, involving a air vaccume, fluid pump, drain plug probe and regulators.
  10. May 19, 2017 at 9:57 AM
    illogical
    illogical Well-Known Member
    2017 TRD 4x4 OR MT
  11. May 19, 2017 at 10:06 AM
    eon_blue
    eon_blue Most Improved Member
    Manuals are full when the fluid reaches the fill port and starts to drip out...overfilling a manual trans doesn't make sense unless they filled it through the top by removing the shifter in the cab. Maybe that's how it's done in the factory but usually when you get a fluid change its done via the fill port.
  12. May 19, 2017 at 10:11 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    you ask the ecu how hot it is, using the special procedures outlined in the toyota document that tell
    how to check and adjust fluid in the trannies
    it is not a mystery, it just takes detailed and specific setup steps and time. then open the hole and see if it drips or not
  13. May 19, 2017 at 10:21 AM
    DallasTX
    DallasTX Well-Known Member
    2015 4x4 AC
    I was thinking the same thing. OP originally said "Had my dealer do a manual transmission fluid check" then three post down said it was an automatic, so a little confusing.
    I only put oil in my manual transmissions, not fluid, and all of the ones I have owned were fill to they drip out the fill hole.
  14. May 19, 2017 at 10:28 AM
    wingfiry
    wingfiry Well-Known Member
    Atlanta
    2016 TRD Sport 4x4 AC MT White
    I think the confusion on the posting and questions is the difference between a "manual transmission" fluid check and a "manual" transmission fluid check. Simple lack of punctuation causes all sorts of confusion.
    eon_blue likes this.
  15. May 19, 2017 at 10:30 AM
    wild toyote
    92 Volvo 240
    Ok great, thanks 127.0.0.1 for clarifying this information. Fixed the OP! Sorry for my bad punctuation.
  16. May 19, 2017 at 10:36 AM
    DallasTX
    2015 4x4 AC
    Yep. Agree! Wondering how you would do an "automatic" check of the transmission fluid? :notsure:
  17. May 19, 2017 at 10:38 AM
    wingfiry
    Atlanta
    I think that's the difference between plugging a computer into it vs physically checking the fluid level.
  18. May 19, 2017 at 10:45 AM
    DallasTX
    2015 4x4 AC
    Now I know why I like stick shifts. No computer or dealer service center needed to check the oil level.
  19. May 19, 2017 at 10:57 AM
    eon_blue
    ohhhh, haha. Yeah, I read it as a manual transmission not an automatic. My bad, carry on....
  20. May 19, 2017 at 12:16 PM
    GPsevinSixx
    GPsevinSixx Well-Known Member
    Ros Angerus
    2015twoAX2.4techPAWS
    6112/5160AALfnCNTSTRyokG015
    Temp sensor and "tool kit" are built into the truck..
    The jumper wire was the only thing I used IIRC at the diagnostics port.
