transmission overheating on hills
Discussion in '1st Gen. Tacomas (1995-2004)' started by K DUB, Dec 28, 2013.
  1. Dec 28, 2013 at 10:51 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Yes.
    The OEM cooler, and the ONLY cooler on vehicles without a towing package, is located inside the "cool" radiator tank.
  2. Dec 28, 2013 at 11:50 PM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    My 98 and 04 both have tow packages. There was not an additional cooler. Just the factory rad with the trans oil cooler built in.
  3. Dec 29, 2013 at 4:27 PM
    K DUB
    K DUB [OP] Member
    oregon
    02 DC TRD 4x4 V6
    285/75 TOYO R/T on 16 alloys,k&n cold air intake, ARB bullbar, icon 2.5 w/ ccdv extended travel coilovers , icon upper control arms, tundra brake upgrade, Dakar leaf pack, greaseable shackles, wheeler's anti-sway kit, spydertrack wheel spacers 1.25",tranny cooler, IPF fog lights, LED headlights , rack it lumber rack, AIR lift airbags
    ok thank you that is what i thought, and the koyo radiator looks higher quality than cheaper ones online, probably worth the extra 60$.
  4. Dec 30, 2013 at 1:41 PM
    K DUB
    K DUB [OP] Member
    oregon
    02 DC TRD 4x4 V6
    ok today i am replacing the radiator , thermostat and hoses, flushing the coolant and replacing the tranny fluid.reconnecting the new internal cooler and then the aftermarket cooler, hopefully this should fix the overheating. praying the cooked fluid hasnt harmed the tranny so far, thanks for all the advice any open to any more about this.
  5. Dec 30, 2013 at 3:58 PM
    lipster
    lipster Well-Known Member
    Northern MN
    2004 ext cab 3.4 auto TRD
    License plate frame
    Not much left unturned.
    Let us know how this works out after all these new parts.
    I'm thinking your truck simply wanted some Christmas gifts to wear...
  6. Dec 30, 2013 at 7:35 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    What color is the fluid you are draining out? If it is still red and not brown, and doesn't smell burned, your trans is probably okay.
    Might have cut some of the life off of the end, but if you're shifting okay now you're probably okay.
  7. Dec 30, 2013 at 9:03 PM
    K DUB
    K DUB [OP] Member
    oregon
    02 DC TRD 4x4 V6
    ended up needing new belts as well as a new timing belt and water pump, not expecting that but i guess i should with 200k on the clock. will report color of fluid after im finished and how all is working out along with the new OME setup i just installed as well. :) happy new year y'all, thanks again for all the advice
  8. Dec 30, 2013 at 10:40 PM
    koditten
    Kirk
    Central Michigan
    It's a lot easier to change out the timing belt and water pump with the rad out the way anyways. You are doing the machanic (hopefully new) a favor.
