Transmission overheating?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Krazie Sj, Nov 13, 2014.
  1. Nov 15, 2014 at 5:39 AM
    Kolunatic
    Kolunatic Broke ass
    Kevin
    Texas
    07 DC peerunner
  2. Nov 15, 2014 at 6:53 AM
    xbxb
    xbxb Well-Known Member
    Jim
    O.P. Kansas
    2013 SR5 DC, SB, 4WD Pyrite Mica,
    undercover flex, Clazzio seat covers, Flyzeyes, Pop N Lock, Shackle to drag me out
  3. Nov 15, 2014 at 9:39 AM
    Krazie Sj
    Krazie Sj [OP] Resident Jackass
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Borla Catback Exhaust, Snorkel, 33s on either 16's or 18's, ARB Bumper, All Pro LT w/Walker Evan Shocks front and back, All Pro expedition leaf pack, 10,000lb Superwinch, Intake Manifold Spacer, Bed Rack with ARB RTT, Rotopack and Hi Lift mounted, Husky Liner mats and an air freshener from 1995.
  4. Nov 15, 2014 at 1:45 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Just doing the change now. See how it goes. Did the flush instead of the simple drain pan change. Still won't know if it's a simple top up or something more serious till I get on the highway and heat things up.
  5. Nov 15, 2014 at 2:51 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    What would analyzing do for me? Just tell me if the fluid was overheated or not?
  6. Nov 15, 2014 at 3:04 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    I know with engine oil they can tell what components are wearing by analyzing the fluid and seeing what metal particles are in it. They can probably do the same with tranny fluid.
  7. Nov 15, 2014 at 4:16 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Rgr. I'll look into that.
    Finished the drain and fill. Took over 30 minutes in 30*F to get it to correct temp. Did the check drain to dribble and now taking it for a rip out and about.
    So far seems okay. Haven't tried any hard shifting in it to see if it slips. The real test will be the highway.
  8. Nov 15, 2014 at 4:25 PM
    moondeath
    Pa, Gardners
    Good luck to you. I hope it works out.
  9. Nov 15, 2014 at 4:27 PM
    gearcruncher
    Canadain bumper technician
    Sorry bout posting a double link to that thread hehe , did a 16 hour shift yesterday and was half dead when I got home .
    I am interested to know what you got for trouble codes ?
  10. Nov 15, 2014 at 8:04 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Haven't yet. Checked the coolant level when at optimal temp. Level was smack dab in the middle.
    I'll be keeping a close eye on it. I also throw in 1/3 bottle of Lucas transmission fix.
    Ripped around town kinda hard to see if I could stress test the tranny. No issues. Kinda feels a little sluggish. Might just be me though.
    See what my mileage is later. If it's sluggish that'll tell me.
    I'm keep you guys posted as to the codes too.
  11. Nov 18, 2014 at 9:12 AM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    Did the code reader. No codes found. Still feels like the truck is a little sluggish.
  12. Nov 18, 2014 at 10:17 AM
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    you should actually have both radiator fluid tested for ATF and transmission fluid tested for coolant.
    you are likely to find no visible or 'simple' problems when systems are not running and not pressurized.
  13. Nov 18, 2014 at 4:21 PM
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    ^True enough. That was my thought as well. I've saved the fluid from the tranny and it's easy enough to drain some from the radiator if need be. I found a place in Calgary that does it, so I just need to contact them regarding pricing.
  14. Nov 18, 2014 at 4:58 PM
    gearcruncher
    I have seen a lot of transmissions get damaged from antifreeze in the oil .With this said , the transmission fluid is very visible within the rad . Usually the first thing you see when you open up the rad cap is oil floating around on top of the antifreeze .I am certain even a small leak would show the same results . Regardless , it wouldnt hurt to send a sample to the lab .
    As far as overheating goes , there are a couple known issues with the valve body on higher mileage units you may want to look at before things get worse .
    Gonna call it out and recommend you get your valve body overhauled .
    http://www.sonnax.com/parts/3477
    Edit : considering your temp light was coming on at highway speeds ,I would suspect this could be the problem . You didnt have any trouble codes stored in the ecm memory so we must assume the issue is mechanical at this time http://www.sonnax.com/parts/1784
  15. Nov 19, 2014 at 8:21 AM
    #35
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    That link made my eyes cross.
    S14Jimbo likes this.
  16. Nov 19, 2014 at 9:14 AM
    #36
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    In the spirit of Hockey season, Puck that.
    Didn't see any tranny fluid in the coolant nor on the outside of the coolant reservoir where it might have spilled out.
    That being said, would it be prudent to get an AM Tranny bolt on rad seperate from the engine coolant rad?
    Additionally I'm guessing that Zip Kit isn't a 3 hour afternoon project hey?
  17. Nov 19, 2014 at 11:01 AM
    #37
    gearcruncher
    About 3 hours for a seasoned technician to install the zip kit and with a guess here, 5 hours for someone who has never done one . All instructions come with the zip kit .Last time I priced out the zipper , it was $300
    Its mostly remove and replace work and having a clean workspace to do the job
  18. Nov 19, 2014 at 11:08 AM
    #38
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    please resolve your coolant loss and transmission overheat issue first
    but yes if you want to add an external tranny cooler and bypass the heat exchanger just be sure to set it up correctly and watch the temps (scanguage will do it) yotatech 4runner forums have a ton of info as well as tacoma forums
    you don't want a homebrew solution getting too cold in winter or too hot in summer.
    when you go full external you now have to worry about how it actually cools which can be it's own little engineering puzzle to straighten out. just a switchable fan may be all that is needed
  19. Nov 19, 2014 at 11:31 AM
    #39
    Krazie Sj
    Power Serge
    LV-426 (Acheron)
    07 TRD Off Road 4x4
    ^Roger. Don't worry I won't do something that's hackneyed and shit. I'd research the crap out of it and only do something someone had done before and was proven.
    I should mention that the coolant overflow and the transmission hiccup were about 6 months apart.
  20. Nov 19, 2014 at 1:09 PM
    #40
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    6 months apart ? then go with gearcrunchers guesses
