Transmission overtemp alarm & engine shut-down
Discussion in '3rd Gen. Tacomas (2016-2023)' started by tirediron, Feb 16, 2019.
  1. Feb 16, 2019 at 5:53 PM
    tirediron
    tirediron [OP] Well-Known Member
    Victoria, BC< Canada
    2022 4x4 Sport, Auto, BCM
    Coming home today after a 30km (20mile) drive that I do almost every day of the week... the only differences were that (1) about 100' from my drive way I pulled over to let someone pass as I swing out and back in... after he passed drive tires caught some slush/snow/ice on the shoulder and spun for a few seconds (maybe 15 max); and (2) while backing up the driveway (25', again something I do almost every day), caught a bit more slippery stuff and slipped a bit; again maybe 10-15 seconds. Got into my parking spot and the truck shut down and there was a "Transmission overtemp" alarm on the info display... WTF? Granted it's a Sport and not an OR / Pro, but I should hope that I could spin for more than 15-20 seconds without sending the transmission into alarm..... anyone have any insight on this (2018 DBL Cab, AT, 4WD, V6)
  2. Feb 17, 2019 at 8:01 AM
    tirediron
    Anyone? Thoughts? Seen it before? Insight in to possible cause?
  3. Feb 17, 2019 at 8:15 AM
    na8rboy
    na8rboy 18 DCLB Sport Cement
    WI
    18 DCLB SPORT CEMENT
    What was the RPM, it spinning at? 15 to 20 seconds of spinning wheels at high RPM is a lot longer than you think. It is also a warning, comes on before over heat occurs. To prevent damage.
    To add to this a Sport, OR, and Pro all have same auto transmission wouldn't make a difference. Also if you were spinning and heating trans fluid up and shut truck down right after, you didn't give it time to cool down, by flowing thru trans cooler.
  4. Feb 17, 2019 at 8:30 AM
    Garyji
    Garyji Well-Known Member
    Gary
    Western North Carolina
    2016 BR SR5 DCSB V6 4WD. TRD Pro 17's, BFG KO2's
    15-20 seconds of spinning is a really long time.
    G.
  5. Feb 17, 2019 at 8:36 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    Going backwards pushes no cool air over the radiator. This happens to Tundras too.
  6. Feb 17, 2019 at 8:46 AM
    tirediron
    "Spun" might have been a poor choice of words; I never completely broke traction, but the rear wheels were going a bit faster; maybe 2000 for about 10 seconds the first time and a bit less the second. My total 'backing up' distance including lining up on the road and the 25' of the driveway was less than 40'and total time in reverse was under a minute. At NO time did I mash the pedal, and at no time were the revs unreasonably high. I'm willing to put the overtemp alarm down to an anomaly, but the fact that it shut the engine down? That's downright dangerous.
  7. Feb 17, 2019 at 8:47 AM
    koditten
    Kirk
    Central Michigan
    See if you can make it happen on purpose.
    Dirtridercrf250 and shakerhood like this.
  8. Feb 17, 2019 at 10:40 AM
    trackdaybro
    trackdaybro Well-Known Member
    Wonder if your transmission cooler is blocked. Take a quick peek.
  9. Feb 17, 2019 at 2:00 PM
    tirediron
    Trans cooler appears fine; nothing blocking it, and no issues today, 'though the snow has melted enough that I was unable to accurately recreate the scenario.
  10. Feb 17, 2019 at 2:05 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    I gone 200 to 300 metres (1000ft) in a low traction scenario, with one or more wheels spinning. No overtemp. I’m thinking some ice or snow yanked a sensor wire out.
  11. Feb 17, 2019 at 7:07 PM
    kapn
    kapn Well-Known Member
    Annapolis, MD
    2016 TRDORLB Blue
    I had this happen on an icy trail. I was slowly creeping in 4 low, not spinning much at all. Surprised me and I restarted and continued the rest of the day with no issues. Not sure why it happened and haven’t seen it since.
    tirediron[OP] likes this.
