Transmission pan bolts loose?
Discussion in 'Technical Chat' started by Jojee117, Jul 10, 2020.
  1. Jul 10, 2020 at 12:49 PM
    Jojee117
    Jojee117 [OP] Well-Known Member
    Joe
    MT
    06 TRD Sport Prerunner 4WD swapped
    Hey guys, just found a small leak coming from the back of my transmission pan. It isnt even enough to form a drip, just a streak of film that reaches the front of the pan. I figured I'd check how tight the pan bolts are just to see if they were loose, and they were. Because I just moved, I dont have access to all of my dads tools such as a torque wrench so I barely tightened them with a ratchet. Are they easily torqued past spec, or are they supposed to not be tight? I'm familiar with guessing how tight is good, but ALL of the bolts were easily tightened an additional quarter turn if not more. I have a torque wrench on the way, but just wondering what your guys experience is.
  2. Jul 10, 2020 at 12:50 PM
    Bishop84
    Bishop84 Well-Known Member
    I actually don't use torque wrenches on most pans, I go by feel because you're crushing the gasket and the aluminum is very soft and easy to break threads.
    Becareful, stick to 1/4" and just gentle tighten is all it needs.
    12TRDTacoma likes this.
  3. Jul 10, 2020 at 12:52 PM
    Jojee117
    Joe
    MT
    That's what I did, but it was concerning that all of the bolts needed to be tightened. The transmission was just replaced a couple months ago, maybe the gasket finally seated from heat cycling and needed retorquing?
  4. Jul 10, 2020 at 12:54 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I only ever use a 1/4" ratchet
  5. Jul 10, 2020 at 1:00 PM
    coopcooper
    coopcooper certified youtube mechanic
    alberta canada
    black on black on black 05 trd off road
    stickers and sticker accessory's
    yeah they don't need to be that tight. if you crush the gasket too much it will leak
    Edit: unless you deleted it and just use rtv
  6. Jul 10, 2020 at 1:02 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    ^^ This. Torque spec is for noobs anyways. Seriously.
    Lester Lugnut likes this.
