Transmission Pan Leak
Discussion in '1st Gen. Tacomas (1995-2004)' started by Carolina, May 24, 2025.
  1. May 24, 2025 at 6:47 AM
    Carolina
    Carolina [OP] Member
    David
    S.C.
    03 Tacoma SR5
    2 INCH LEVELING KIT
    2003 SR5 4x4 Automatic 3.4
    I noticed my transmission pan gasket leaking, checked bolts for tightness and several of them are stripped. Not because I over tightened them, there literally just spinning and held in by RTV (previous owner).
    Im thinking of either helicoil, or tapping and going up a size on the bolts.
    I’ve noticed that there is not a lot of material to work with and tap.
    Anyone ever deal with this problem and have any suggestions?
  2. May 24, 2025 at 10:21 AM
    koco
    koco Well-Known Member
    Bay Area Ca.
    '01 Taco
    Around $26,000 worth of unleaded in the fuel tank.
    If they are indeed stripped out you can use a helicoil thread insert that will accept the original bolt size. Try using a tap with the original size first, it might work.
    ControlCar and Carolina[OP] like this.
  3. May 24, 2025 at 10:35 PM
    JustADriver
    JustADriver Well-Known Member
    1996 Tacoma 3.4L V6 2WD 5-lug AT 5VZ-FE
    It's an ideal application for Helicoil. M6 x 1.
    Carolina[OP] likes this.
