Transmission Pan replacement
Discussion in '1st Gen. Tacomas (1995-2004)' started by TWM2001, Nov 11, 2009.
  1. Nov 11, 2009 at 2:57 PM
    TWM2001
    TWM2001 [OP] Active Member
    Ray
    Pascagoula, MS
    2001 double cab V6
  2. Nov 11, 2009 at 3:26 PM
    TWM2001
    Ray
    Pascagoula, MS
    2001 double cab V6
    local dealer wants $110. Part # 35106-34020
    Didn't find any on eBay nor in a casual Google search. Is the dealer or junk yard my only options?
  3. Nov 11, 2009 at 3:28 PM
    TWM2001
    Ray
    Pascagoula, MS
    2001 double cab V6
    Found this parts list but can't find a retailer that sells it by that part number!
  4. Nov 11, 2009 at 10:35 PM
    FuTang909Inamo
    FuTang909Inamo Well-Known Member
    Socal IE
    03 TRD PreRunner
    Deckplate mod, Trueflow drop in filter, clear corners, 31 BFG A/T on 15x8 Mb Razors.
    Why are you replacing the entire pan if it's only the drain plug that is stripped? Did you try a new plug and gasket and still had a leak?
  5. Nov 12, 2009 at 6:58 AM
    Dawayne409
    Dawayne409 Master Airman of the Navy
    Dawayne
    Norfolk, Va
    01 V6 Prerunner SR5 Stepside
    Glassworks Front Fenders, SAW Racerunner Coilovers up front, Awesome mangled up back bumper, Tailgate is currently MIA.
    Is it just the plug thats stripped our is the heliocoil and everything stripped? Its not too hard to get a new bolt and rethread the heliocoil, probably alot cheaper too.
  6. Nov 12, 2009 at 8:19 AM
    TWM2001
    Ray
    Pascagoula, MS
    2001 double cab V6
    The drain plug was a bear to break loose and it just spins in the threads; will not tighten back nor will it be fully removed. I have tried all I can and also took it to Advanced where my good friend works and he cannot get the plug out and says a heliocoil will not suffice.
  7. Nov 12, 2009 at 8:25 AM
    TWM2001
    Ray
    Pascagoula, MS
    2001 double cab V6
    Original pan and most likely original gasket and filter. I had a leak around the pan so in trying to replace the gasket and filter I was unable to get the plug out and had to drain the fluid by taking all the bolts out and draining by prying a corner of the pan off and being patient.
    On the plug is stripped, appears supremely cross threaded.
  8. Nov 12, 2009 at 9:12 AM
    TWM2001
    Ray
    Pascagoula, MS
    2001 double cab V6
    local transmission place says he can "patch" weld my pan with a piece from a 19 bolt (4x4) pan for about $25. Cut out the drain plug area and replace from different pan so plug is still usable.
    Beats $110 new from factory and no junkyards around have a pan for a V6 2WD so...
    Good idea or not?
  9. Nov 12, 2009 at 9:13 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    You could always just have a new bung (huh huh) welded in.
  10. Nov 12, 2009 at 9:16 AM
    FuTang909Inamo
    Socal IE
    03 TRD PreRunner
    Gotcha...well there's another option. I did it with an oil pan. Took the whole oil pan off, took it to a machine/weld shop and they cut out the old drain and welded me a new one. It's a cheap solution i think.
  11. Nov 12, 2009 at 9:16 AM
    TWM2001
    Ray
    Pascagoula, MS
    2001 double cab V6
    You mean bungholio? Really, what's a new bung welded in mean? :)
  12. Nov 12, 2009 at 9:18 AM
    TWM2001
    Ray
    Pascagoula, MS
    2001 double cab V6
    Same concept but with the transmission pan. I'm going to assume becuase Id o not know any better that being patched properly will make it just as durable as the factory equipped and will not blow out while driving or spring a leak because of the weld.
  13. Nov 12, 2009 at 9:24 AM
    FuTang909Inamo
    Socal IE
    03 TRD PreRunner
    I did it with an old vw scirocco...yeah it worked pretty good.
  14. Nov 12, 2009 at 9:52 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    X2 As long as you take it to a competent welder.
  15. Nov 14, 2009 at 12:41 PM
    TWM2001
    Ray
    Pascagoula, MS
    2001 double cab V6
    Got the pan back and even though the guys told me they would cut out old and weld in new all they did was get the bolt out, still charged me $25!
    I'm thankful they got the bolt out and it appears to be able to maintin a good bite but charging $25 to do it! Don't think I'll ever go back there...
    Anywho got the gasket up and pan mounted but the filter kit I bought did not have the correct filter...Oreilly's does not seem to have a good description in their DB when it comes to Tacoma transmissions. So I cleaned it best I could with a pressure washer up close and some carb cleaner and let it dry today.
    I bought 12 qt's of Oreilly's global ATF, anybody ever use this stuff? They have a limited selection and no mobil 1 that's for sure. My plug says DXII and this is compitable so any experience with this stuff?
  16. Nov 15, 2009 at 8:34 AM
    TWM2001
    Ray
    Pascagoula, MS
    2001 double cab V6
    Anyone?
