Transmission Pan Replacement
Discussion in '2nd Gen. Tacomas (2005-2015)' started by persian451, Aug 24, 2020.
  1. Aug 24, 2020 at 8:58 PM
    persian451
    persian451 [OP] Active Member
    Peter
    Woodbridge, VA
    2006 TRD Sport
    bone stock
    Spent the weekend following Fortech's awesome DIY instructions for the transmission drain/refill on my 2006 Prerunner TRD Sport.
    Everything went great, except I noticed the f****** stealership mechanics cross-threaded the drain bolt. Pleasant surprise. Pretty annoying since the truck has always been service at Toyota.
    Question for all of ya:
    1. Should I try replacing the drain bolt or should I just replace the pan? The existing cross-threaded bolt just spins on the pan when i screw it back in... i have a feeling that the threading is also jacked on the pan, but I'm not sure.
    2. If you replace the pan with the gasket, do I need to use RTV to keep the gasket on the pan to help with the installation? Are there any tips/tricks for the pan replacement?
    Aside from the pan, gasket, and a new drain bolt, is there anything else I should pickup?
    Gasket #3516860010
    Pan #351060C010
    Plug #9034110021
    Appreciate any feedback
    Cheer!
  2. Aug 24, 2020 at 9:06 PM
    Bishop84
    Bishop84 Well-Known Member
    No sealant, just dry and wipe clean. Consider inspecting your pickup screen while its off. Becareful with the 10mm bolts, they can strip if overtightened.
    gearcruncher likes this.
  3. Aug 25, 2020 at 2:21 AM
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    PML sells a deeper pan. I was lucky enough to get one of their promo pans almost a year ago. It added about 2.5-3 qrts of extra fluid.
  4. Aug 25, 2020 at 4:51 AM
    TheDevilYouLove
    TheDevilYouLove You can’t polish a turd, but you can polish a TRD
    Marylandistan
    2010 Tacoma TRD Sport Access cab 4x4 silver streak
    Remember that the torque specs for the tranny pan bolts are in INCH/pounds, not foot/pounds. Def don't want to over tighten those. I used a Wheeler FAT wrench which is basically an screwdriver type 1/4 torque wrench that measures in inch/pounds when I did my pan drop to replace the filter. Oh yeah, since you're dropping the pan anyway you may as well replace the trans filter in there.
  5. Aug 25, 2020 at 7:38 AM
    dtaco10
    dtaco10 Well-Known Member
    Dave
    Anoka County, Minnesota
    2010 White Tacoma 4x4, 4.0, Auto
    BillsSR5 likes this.
  6. Aug 25, 2020 at 7:45 AM
    BillsSR5
    BillsSR5 Looking out for #1
    bill
    2014 SR5
    retap the plug hole to larger size like dtaco10 says, you may still be able to use the OEM washer, if not get an equvilent at the hardware store, if that don't work then its new pan time. also those bolts are 15 ft/pds torque and the can strip out very easily that's why they incorporated the oem crush type washer to try a reduce the stripping, I would torque to no more than 12 ft/pds to be on the safe side ive did this no leaks and was able to reuse the washer a few more times before getting a newbie
  7. Aug 25, 2020 at 8:04 AM
    persian451
    Peter
    Woodbridge, VA
    2006 TRD Sport
    bone stock
  8. Aug 25, 2020 at 8:05 AM
    BillsSR5
    bill
    2014 SR5
  9. Aug 25, 2020 at 8:11 AM
    BillsSR5
    bill
    2014 SR5
  10. Aug 25, 2020 at 8:27 AM
    persian451
    Peter
    Woodbridge, VA
    2006 TRD Sport
    bone stock
    Seem simple enough. I'll give that a shot before spend the $ the pan/gasket.
    For the Dorman oversized plug, would you guys swap out the gasket washer with the crush washer? or use both?
  11. Aug 25, 2020 at 8:30 AM
    roadking1
    roadking1 Well-Known Member
    n.j.
    2023 Solar Octane TrdPro 6-speed manual
    doesn't the dorman plug come with a washer? I used one of them on a stripped out oil pan.it worked great.
  12. Aug 25, 2020 at 8:35 AM
    persian451
    Peter
    Woodbridge, VA
    2006 TRD Sport
    bone stock
    The one I'm looking at looks like it comes with a rubber gasket: https://www.napaonline.com/en/p/NDP7043016
  13. Aug 25, 2020 at 8:54 AM
    roadking1
    n.j.
    that will work well.
  14. Aug 25, 2020 at 12:21 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Put grease on the tap to retain metal shavings.
  15. Aug 26, 2020 at 7:48 AM
    BillsSR5
    bill
    2014 SR5
    at this time id just use the dorman washer, we know it fits the plug right, just torque it no more than 15 ft/pds that's the oem torque on the old plug,
