transmission problem.......fluid adding problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by tacomaman06, Nov 29, 2010.
  1. Nov 29, 2010 at 4:06 PM
    tacomaman06
    tacomaman06 [OP] Carolina Alliance: Enforcer
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well.....2 weeks ago, i did a drain and fill on my 04. i put in 3 quarts, and it checked right on the mark on the cool level. lately....my 3rd and 4th gear shifts(automatic) have been kinda long/hesitant a bit. so today.....checked the fluid after driving home for 45 minutes, and the dipstick showed oil on the cool mark, so i figure im a quart low. so, i add a quart, drive around the block, and recheck....still in the cool zone. im not sure what to do really. im thinking i should add another quart, but i cant figure why its reading that way. any of yall ran into this and have any ideas??
  2. Nov 29, 2010 at 5:02 PM
    EL TACOROJO
    EL TACOROJO SNAPPIN NECKS AND CASHIN CHECKS.
    BURRY
    south mills NORCAK
    03 dblcab prerunner sr5 v6
    smoked taillights,smoked front turnsignals,smoked 3rd brake light,black badges,black roof rack,removed mud flaps,debadged, camburg 2.5 coilovers,camburg uca's, cobra 25 cb, 4ft firestick ant, dust light/bed lights , 4 hellas on the front
    hmmm i think it takes more than 4 quarts . you have the torque converter and the pan
  3. Nov 29, 2010 at 5:13 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    but thats the thing....all i did was a simple drain and refill......which i thought was 3 quarts, but its not showing on the "w" mark on the dipstick..even after driving for a bit.
  4. Nov 29, 2010 at 5:13 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    A drain and fill should only take 2 liters. A dry fill will take 10 liters.
  5. Nov 29, 2010 at 5:16 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    well......as i mentioned,all i did was a drain and refill.....added 3 quarts and it read on the cool mark. even after driving...it still doesnt show on the warm mark. after adding an extra quart today...after its shut off...it's reading on the warm mark. if i crank it up and go thru thye gears...it'll only show in the cool mark...even after driving a litle bit/around the block. see...i checked it today after driving home 45 minutes from work....and it wasnt on the warm mark.
  6. Nov 29, 2010 at 5:18 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
    5 to 5 1/2 quarts
  7. Nov 29, 2010 at 5:28 PM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  8. Nov 29, 2010 at 5:35 PM
    EL TACOROJO
    BURRY
    south mills NORCAK
    if your doin a dry fill the converter gets filled when flat before it is installed then you fill the trans thats how you get the 10 qt dry fill. so in turn when you drai half the converter liqued comes out along with the pan fluid
  9. Nov 29, 2010 at 5:37 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    how much came out when you drained?
  10. Nov 29, 2010 at 6:25 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    i wasnt able to tell this time.....all my containers were full.:eek:
  11. Nov 29, 2010 at 6:32 PM
    brutalguyracing
    brutalguyracing BIG DADDY
    F.U> GUYZ
    broken mods
    possible you were low before the drain and refill?
  12. Nov 29, 2010 at 7:05 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    yeah man...its possible...because last time I only added 3 qts back in. I have 4 in now....and gonna
    Add a 5th one.
  13. Nov 29, 2010 at 7:57 PM
    '02TRD
    '02TRD Well-Known Member
    Portland, OR
    2002 Tacoma Xtra Cab 4x4 SR5 TRD
    Billstein 5100's & AAL, 285/75R16 Toyo Open Country M/Ts on Black 16x8 Raceline Renegades, Pro-Tech Toolbox, Wet Okole covers, K&N air filter, Tow package, Alpine digital media receiver, Kenwood Amp, Rockford Fosgate 10" sub, Cobra 75 hand held CB, front differential drop
    perfect time to get a 5-speed. jk i know how bad transmission troubles can be though, good luck
  14. Nov 29, 2010 at 8:42 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ahaha....dude....i WAY too lazy for a 5 speed. and i drive in alot of traffic back and forth to work. tired as hell morning and evening..and 5 speed and me....no bueno!!:D
    well....im gonna add the 5th quart tomorrow after worka and drive it home and see how it does. im gonna get it flushed soon as well...maybe this weekend or next.
  15. Dec 4, 2010 at 10:37 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    did my transmission flush today......and did it with 12 quarts of t4. does 12 quarts sound about right?
  16. Feb 5, 2012 at 11:44 AM
    dbrosnan2009
    dbrosnan2009 Member
    Dan
    NewBern NC
    04 tacoma 2wd
    not a one
    Hello, I am new to the forum. This is confuising to me. I drained my 2004 V6, 5VZ, 2 wd transmission by removing the plug on the bottom of the pan. I do not know how much came out as it went into a large waste container. The owners manual says drain and fill "up to 2" which I assumed was 2 quarts. I put 2 quarts of toyota type IV and drove a few miles and checked ..... ATF reads way low. My dipstick has 4 notches. Two notched down low by the cold and 2 nothes up high by the hot. Does any one really know how many quarts of ATF are needed to refill after draining from the plug on the bottom of the pan? Also what is the correct way to check the level? In park or in neutral? How hot does the fluid need to be?
  17. Feb 5, 2012 at 11:56 AM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    needs to be driven at least 15 minutes to heat up the fluid. and dont go by the manual in this case...its wrong. 4 quarts for a drain and fill will put it where it needs to be.
    http://www.tacomaworld.com/forum/1s...nsmission-fluid-dipstick-reading-inquiry.html
