TRANSMISSION PROBLEM - HELP PLEASE!
Discussion in '1st Gen. Tacomas (1995-2004)' started by skeedermigee, Dec 2, 2010.
  1. Dec 2, 2010 at 10:54 AM
    skeedermigee
    skeedermigee [OP] New Member
    Oregon
    2003 Tacoma dbl cab 4x4 3.4l
    (2003 Tacoma double cab 3.4l auto trans 130k) So the other day I drained my tranny fluid and took my car (while truck was sitting in garage) to store to get more fluid. While I was gone my GF took my truck down the road to drop mail off in outgoing postal box (about a mile away). When I came home I freaked out of course but my fault for not saying anything. She said "yeah it drove really crappy and clunky." Anyways- now I have refilled it with (valvoline high mileage/max life tanny fluid) It seems to drive less responsively and slightly slugish. In addition it sometimes will not be engaged in gear from a stop sign and will rev then SLAM into gear. My first instict was to switch back to a less viscous tanny fluid/ toyota type5. But before I spend any more money I want to know possabilities of problem. Valves/solenoids in tranny sticking? I dont know please help!
    Lukass likes this.
  2. Dec 2, 2010 at 10:55 AM
    skeedermigee
    Oregon
    PS- IF YOU REALLY REALLY FEEL QUALIFIED TO HELP ME PLEASE FEEL FREE TO PM ME.
  3. Dec 2, 2010 at 10:57 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Only thing you can do at this point, is make sure the fluid level is correct. Im betting there is air in the system,. and it may take time to clear it out.
    Lukass likes this.
  4. Dec 2, 2010 at 11:17 AM
    xsvtoyz
    xsvtoyz Well-Known Member
    AL
    Oklahoma
    03 Pre-Runner Inprogress
    HID (ACA)/ Web cams/ Header/Full Custom exhaust/ K&N FIPK II/SuperCharger
    very true
    did you compare how much came out to how much went back in? and from what I understand toyota is kinda picky about what auto fluid it uses yota fluid is pricey but may be worth it
    it could also be you are looking for faults
  5. Dec 2, 2010 at 11:29 AM
    tacobo670
    tacobo670 if you have to ask, u can't afford it
    Ray
    Las Vegas
    Tacoma Sport 4x4 AC 6spd
    Super cherry n some champion stuff on the side
    its done. the tranny is toast. its just a matter of time before it shits itself IMO.
    Lukass likes this.
  6. Dec 2, 2010 at 11:45 AM
    twfsa
    twfsa Well-Known Member
    Tom
    Omaha Ne
    04 TRD 4X4
    881 Front coils, Bilstien 5100's all the way front set to "0" Icon Dynamic's mini leafs in rear, stock tires.
    ^^^ what he said..........dump the chic too!
  7. Dec 2, 2010 at 11:55 AM
    desertdude59
    desertdude59 CRAZY 4WHEELER
    From the Mojave desert now in Wild and Wonderful W
    1991 toyota 4x4 sr5-lost but not forgotten
    4" lift after market front bumper bed mount lightbar/roll bar (4)6" kc's on the roll bar (2) kc flat back bumper mounts f/r gears for the 33's
    Sounds like its TOAST!
    Lukass likes this.
  8. Dec 2, 2010 at 12:01 PM
    90YotaPU
    90YotaPU The Messiah
    Union County, NJ
    1990 Toyota 4x4 (Pre-Taco)
    Aftermarket Stereo, Spidertrax Wheel Spacers, HF Air Horns, 3" Lift
    I would be surprised if the trans was toast. I've seen many transmissions come with low to no fluid (on the dipstick) and put fluid in them and they were fine. I think it just needs time to work the fluid into it's system. Don't forget even after you drain an auto trans, there's still 1/3 of the fluid in the torque converter. Knowing how an auto trans works, it seems the problem is that the fluid hadn't worked its way in enough to engage the bands fully right away (causing that jerking motion). As previously said, I would watch the fluid level. Once it starts working it's way into the trans, you'll need to add more. Good luck.
    Lukass likes this.
  9. Dec 2, 2010 at 12:02 PM
    TanSR5x4
    TanSR5x4 Hold my beer and watch this
    William
    Houston TX
    00 Tacoma SR5 4x4
    Deckplate mod, black KC slimlight fogs, hurculined bed, NRA sticker mod, painted rear chrome bumper black, black fender flares and front grill surround, HIDs, All-pro rear leafs and UCAs, Eibach coilovers, billys all around, flat black pro comps, 31x10.5x15 BFG KM2s
    wow
    sweet jesus that is really something
    Lukass likes this.
  10. Dec 2, 2010 at 12:04 PM
    MAXTacoma
    MAXTacoma Well-Known Member
    Lexus GS 350
    ^ My 98 4Runner w/ the 3.4 auto (i'm guessing the same trans) did the same thing after I had the transmission fluid changed. (A friend of the familiy changed it) Everytime I would go to a stop sign and try to accelerate it would slip then slam into drive. But it didn't do it for about 150 miles afterward. I drove it for about 3-5k like that before I had Toyota change the fluid (I know not the smartest but I didn't have the money to have anyone else check it). After Toyota changed the fluid it never did it again, they told me it was low on trans fluid. I put over 60k on it and never had an issue. I sold it with over 140k.
    Lukass likes this.
  11. Dec 2, 2010 at 1:12 PM
    skeedermigee
    Oregon
    Thanks guys your great! And its awesome to have such promt replies. So I would too agree that my tranny is NOT TOAST- and that totally makes sense with having air in system and needing to work its way back into the system. I will go pick up genuine Toyota fluid this week and redrain and refill and get back to all of you on how it turns out "Im remaining optomistic" I cant really understand how it would be toast, I dont think these are the symptoms you would see if my GF burned something up inside the tranny or really did some damage so those of you who think its TOAST- I HOPE YOU ARE NOT RIGHT!!! lol Thanks guys- Ill post back in a couple days or a week or so.
    Lukass likes this.
  12. Dec 2, 2010 at 1:17 PM
    tacobo670
    Ray
    Las Vegas
    true. but fluid was drained. no plug reinstalled. wife drove it, guarantee all the residual fluid in lines all came out. trans was drying up. sticky clutch packs, tq converter not good. valve body no fluid circulation = bad situation IMO
  13. Dec 2, 2010 at 4:32 PM
    Cb2589
    Cb2589 Well-Known Member
    Corey
    VA
    97 Tacoma, 5spd 2.7L
    Wheelers Offroad black steel wheels, 12 disc changer, spray in bedliner, Black UWS toolbox, Kelly Safari TSR's, Dynomax Super Turbo
    When you drain it and refill again, start it up and run it through the gears a couple times, keep checking it till it's full.
  14. Dec 2, 2010 at 5:24 PM
    90YotaPU
    Union County, NJ
    I was assuming he finished draining and put the plug back in before leaving to get fluid. It doesn't specify. If the plug was left out then yea I would agree the the fluid went pouring out. Hopefully it's not toast.
  15. Dec 2, 2010 at 11:13 PM
    skeedermigee
    Oregon
    The plug was in when she drove it and problems do seem to be slowly dissapating since i refilled the tranny, the slamming into gear was only happening a few times a day- Im still going to drain and refill ill keep you guys updated. Thanks
  16. Dec 3, 2010 at 6:03 AM
    90YotaPU
    Union County, NJ
    I really don't think you have anything to worry about. My sister came to me the other day complaining her '99 Mustang was acting wierd. I checked the dipstick it wasn't registering any trans fluid. When I asked her how long it was doing that she said a month or so. I filled it, drove it, added more, drove it, and added more and now it's fine. Key is just keep checking the fluid level. As it gets through the valve train and into the servos and what not, the amount of reserve fluid in the pan is going to get low.
  17. Dec 3, 2010 at 6:37 AM
    joerussell610
    joerussell610 When all else fails read the directions
    Him
    Making myself at home in your house
    2005 DC Sport Edition 4x4
    K&N, fog light mod, remote rear halogen fogs mounted under rear bumper, TRD skid plate, Flux Capacitor, Mr. Fusion upgrade soon
    :infantry:Dude shes gotta go!
