Transmission Problem Need Help
Discussion in 'Technical Chat' started by YotaMan2007, Mar 31, 2013.
  1. Mar 31, 2013 at 3:20 PM
    YotaMan2007
    YotaMan2007 [OP] Well-Known Member
    Brian
    where my boots and ruck lay
    07 Tacoma 2wd
    K&N Drop-in airfilter, secondary airfilter removed, Satoshi Mod, Kenwood Stereo System, Gibson catback system , Painted Steelies, Offroad Lights, Fatbob's spacer lift
    Yesterday I went out wheeling with my buddies and i got stuck. after my truck was recovered the wires going to my left tail light were cut and the transmission didn't want to shift out of park. I have the 4cyl automatic. only thing other than it not wanting to come out is the lights for the gear selection on my gauges aren't lighting up. please help
  2. Mar 31, 2013 at 3:23 PM
    2000GTacoma
    2000GTacoma Well-Known Member
    Snow Hill NC
    00 Tacoma Ext. 3.4L SR5
    I bet when the wires were cut to your tail lights it blowed the fuse for the brake lights. The shifter won't move unless your foot it on the brake pedal. Fix wires replace fuses and try it.
  3. Mar 31, 2013 at 3:27 PM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    already did that and still nothing
  4. Mar 31, 2013 at 3:30 PM
    2000GTacoma
    Snow Hill NC
    Recheck the fuse? Are both tail lights working and functioning?
  5. Mar 31, 2013 at 3:32 PM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    fuse is good and all fuctions are working properly
  6. Mar 31, 2013 at 3:46 PM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    the emergency release button lets me take it out of park but the light on the gauge still won't light up
  7. Mar 31, 2013 at 4:32 PM
    YotaMan2007
    Brian
    07 Tacoma 2wd
    After going through every single fuse I found the one labeled as IG1 was blown, i replaced it and now the problem is fixed.
  8. Mar 31, 2013 at 4:39 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    check the IG1 fuses
