transmission problem?
Discussion in '1st Gen. Tacomas (1995-2004)' started by takaya49, Oct 12, 2008.
  1. Oct 12, 2008 at 8:29 PM
    takaya49
    takaya49 [OP] Pacific Rim Mushrooms
    Brent
    Vancouver BC
    tacos
    Fox C/O long travel shox with resi, piggy back fox rears, TC UCA's, ICON AAL, Addicts/17 toyo MT, Mr. Marv set up,
    hey taco lovers.
    so today i found a problem with the taco...
    its an automatic, '98, v6 4x4
    and i dont know for sure its the tranny..
    going up hill (highway driving) and it doesnt wanna gear down... just lugs lugs lugs until i step on it... and its not even smooth once i get in a lower gear.
    so i drive it with the 'o/d off' light on...and almost seems to be fine... slight hesitation but nothing companred to when the 'o/d off' light is off.
    any ideas? fluid looks alright.. would a change make a difference?
  2. Oct 12, 2008 at 8:30 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Drop the pan and change the filter. Sounds like pressure isnt building letting the tranny shift propperly, and the most likely cause would be dirty filter. :)
  3. Oct 12, 2008 at 8:52 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    also want to add thats its really not a good idea to tow without the "overdrive" being turned off.
  4. Oct 12, 2008 at 9:16 PM
    takaya49
    Brent
    Vancouver BC
    tacos
    truck has never tow'd
    thanks guys, hopefully that will fix it...
  5. Oct 12, 2008 at 9:38 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    ah...i didnt fully read what you posted correctly...sorry:eek:
    yeah, changing the fluid and filter should take care of the problem.:)
  6. Oct 17, 2008 at 3:01 PM
    takaya49
    Brent
    Vancouver BC
    tacos
    if there wasnt enough pressure there to create smooth shifting, shouldn't there be a leak?
    fluid looks great and is full...
  7. Oct 17, 2008 at 3:10 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    not necessarily. the filter could be clogged causing not enough fluid to get thru.....even though it may look good and all.
  8. Oct 19, 2008 at 10:15 AM
    takaya49
    Brent
    Vancouver BC
    tacos
    would that not have the same effect on the truck driving with 'o/d off' button on ?
    seems to drive 99% with it on...
    just trying to hear any possible problem before i give it to 'captain b.s.' (mechanic)
  9. Oct 19, 2008 at 11:00 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    On your truck, when the tranny is on OD, the converter locks up, therefore not showing the symptoms you describe as often. With it "OFF", the converter remains unlocked, so you will be able to feel more of the issue.
  10. Oct 20, 2008 at 11:13 PM
    takaya49
    Brent
    Vancouver BC
    tacos
    ok. one more thing... I start the truck up today, put it in gear(without moving and brake on completely) and it starts mis-firing very slightly but noticable, like a dirty fuel filter or a bad fuel injector... still tranny?
  11. Oct 30, 2008 at 10:58 AM
    takaya49
    Brent
    Vancouver BC
    tacos
    it was a spark plug
  12. Oct 30, 2008 at 11:03 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    Damn, atleast your tranny is good. Thanks for the update.
  13. Oct 30, 2008 at 5:32 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    DOH! :frusty:
