Transmission problem?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Barf1up, Dec 16, 2013.
  1. Dec 16, 2013 at 1:05 PM
    Barf1up
    Barf1up [OP] Member
    Ft. Irwin
    08 PreRunner DBl Cab
    Gibson Cat back exhaust
    Hi there i have an 08 tacoma pre runner dc with auto trans. I have this rattle when i put it in reverse. It intensifies when i let off the brakes when its cold. After its been driven for a while it will only do this if i accelerate in reverse. And it does not do this in drive at all. Tonight im going to inspect my u joints the drive shaft and tranny mount as those seem to be common problems.
  2. Dec 16, 2013 at 5:25 PM
    white08gt
    white08gt Well-Known Member
    Al
    Tn
    05 dbl cab 4x4 sr5
    toytec lift, fj rims, a.r.e topper
    check your front brake pads, have you put on new pads? what makes you think it is coming from the trans. exhaust shields, brake shields may all rattle going in reverse. front pads have an anti rattle kit, when i replaced my front brakes i used the old and the new trying to stop the squeal. only squealed in reverse.
  3. Dec 16, 2013 at 5:32 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    Might be the air intake tube rubbing against the inner fender.
  4. Dec 17, 2013 at 10:13 AM
    Barf1up
    Barf1up [OP] Member
    Ft. Irwin
    I have not check the brakes i will look at those this weekend when i rotate my tires. And i thought it was the tranny because it soumds like was coming from there and it only happened in reverse. Also it only seems to do it when its cold after a while it doenst do it.
  5. Dec 17, 2013 at 6:42 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    The intake pipe only made noise when cold on mine too, mine is a standard, but it was low / medium torque on the drivetrain in reverse that made it growl / rattle. Not saying for sure that its the same issue you're having, just easy to check / eliminate.
