Transmission Problem
Discussion in '1st Gen. Tacomas (1995-2004)' started by Ralstondad, Dec 31, 2015.
  1. Dec 31, 2015 at 9:54 AM
    Ralstondad
    Ralstondad [OP] Member
    Cape Cod
    2005 Tacoma Double Cab 4x4
    I was driving about 40 mph when my automatic transmission suddenly disengaged as if it shifted into neutral. I could only go about 1 mph, so I was able to pull off the road, but no matter what gear i shifted into, even trying 4wd high and low, nothing worked. Once I turned off the engine and tried to restart it 30 minutes later it wouldn't even turn over. Any thoughts?
  2. Jan 1, 2016 at 12:22 PM
    gray223
    gray223 Well-Known Member
    SE Missouri
    2014 Tundra Limited
    No check engine lights? And the engine wouldn't even crank? Like at all?
  3. Jan 1, 2016 at 12:24 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    How many miles are on the truck? 4 or 6 cyl? Year/model? Have you done all the regular maintenance for it?
  4. Jan 2, 2016 at 3:35 PM
    Ralstondad
    Cape Cod
    it's a 2001 double cab, V6, TRD with 216,000 miles. I'm the original owner. All regular maintenance has been down faithfully.
  5. Jan 2, 2016 at 3:47 PM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    And no check engine lights? Prolly been answered already. You need to feed the TW beast, you didn't.
  6. Jan 2, 2016 at 8:48 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    sounds like a main relay of some sort. if not the ECU going out.
  7. Jan 3, 2016 at 6:06 PM
    Ralston
    Ralston Well-Known Member
    High in the Rockies
    Super White - 4x4 - TRD Off Road
    F**k it dude, grab a 2015 before they're all gone! It's going to be a while before the 2016+ has the knowledge pool that currently exists. Thank you internet :bowdown: It may be worth fixing this problem before you trade it in though... Where is the truck now?
  8. Jan 4, 2016 at 9:04 AM
    Ralstondad
    Cape Cod
    it's in Aaron's hands, dude...I don't need a new one
  9. Jan 9, 2016 at 6:33 PM
    Ralston
    High in the Rockies
    What's the verdict?
  10. Jan 10, 2016 at 1:54 PM
    Ralstondad
    Cape Cod
    So my mechanic finally diagnosed by problem: broken flywheel. So the part alone will cost $350+...and then there's all the labor...but I guess these things can happen after 216,000 miles
